Old 09-28-2012, 01:36 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Got Sick of the Beep-Beep
I've been playing with the grounding on my home-fabbed horn ring for too long now. Yesterday was the "final straw". I got P.O.'d at one of the neighbors (a few acres away)
for a "sustained" breaking of the country-quiet. Seemed he was running a chain saw or something for an almost unbearable amount of time.
Being a good neighbor, and understanding that *someone* has to work, I went outside to see the direction it was coming from. Not that I was going to get strange...
I just wanted to see where the noise was blurping from.
Okay....It was from under the hood of my truck. I have no idea why...Something to do with my insulating the horn ring with something that didn't like the heat...
Got (ambient temp.) hot and started it's infernal grounding again.
Point: I'm moving the black wire to a "tasteful" intermittent grounding button near the dash. And I don't want to cut the black wire that goes to the plug for the horn relay...
because one day when the weather is good, and all the stars align, I'll get back on it to re-plumb it to the horn ring.
But for now, I'm wondering if there's a way to release the one terminal from in this connector without going at it with side cutters and screwing up the plastic housing that holds the red/green/black
connections in the plug? I already put a small screwdriver in there and tried to "finesse it" around. This is a brand new M & H wiring harness, so I hate to start mooshing stuff up
My normal approach would be "cut, solder, shrink wrap, and be done with it".....But, as I said, I'm trying to NOT cut the black wire, and simply replace it with another black
ground wire directly to the new horn button.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-28-2012, 06:08 PM   #2
Square_78
Square_78's Avatar
Re: Got Sick of the Beep-Beep
HAHA hilarious! Going out to shoot the neighbor only to find out its your own truck making he noise. lol
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 09-28-2012, 06:15 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
I can see we are gonna get along quite well at Rene's
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 09-28-2012, 07:25 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Got Sick of the Beep-Beep
Take a very small flat blade screw driver and insert it from the connection side. There is a small pin that holds it in. When you go back with it make sure you spread it out to catch again. The tiny metal flap clips into the plastic inside the connection.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
