Old 09-29-2012, 06:38 AM   #1
nibulus
nibulus's Avatar
Re: Little help needed: original 1964 C10 front suspension?
Thanks for the reply. Should've mentioned that in the original post.
What about the components around the coil spring (trailing arm/upper spring seat or whatever they are called...)?
What I'm aiming at is whether I can buy regular -64 C10 lowered coil springs or should I go for something else. I guess the spindles will be a risky purchase anyway since I don't know much about the 5-lug conversion apart from the bolt pattern...
nibulus is offline   Reply With Quote
