Old 09-29-2012, 04:29 AM   #1
A.Bursell
Possibly Obvious Brake Bleeding Question
On my 67 I am just finishing up the brakes. I still have the 4 wheel manual drums, but everything except the hard lines and master cylinder is new. Hopefully this gets me some good brakes until I'm ready to upgrade. Anyway, I will want to bleed them when I am done (flush any old fluid out of the system as well). I would start at the right rear as it is normally furthest away from the master cylinder in my experience. I see on this truck, the rear brake line comes over to the right side of the axle and then splits. This makes the left rear the furthest away. Should I start bleeding with the left rear? This makes sense to me, but I would like a little backup since it's not what I would normally do.
Thanks,
Adam
A.Bursell is offline   Reply With Quote
Old 09-29-2012, 08:32 AM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Possibly Obvious Brake Bleeding Question
This info is strait out of the 1967 Chassis Service Manual Quoit ( Bleeding should be done on the longest line first; the proper sequence to follow is left rear, right rear, right front, and left front.)
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-29-2012, 11:48 AM   #3
A.Bursell
Didn't even think to look in the manual-- bleeding brakes seems so basic. That will teach me!
Thanks!
Adam
