Closed Thread
Old 09-29-2012, 12:35 PM   #4976
Clrussell
Clrussell's Avatar
Re: What did you do to your truck today!
Between yesterday and today I've built my 20" drop hitch to pull my mastercraft, made my tailgate hinges, razor bladed all the outside of the glass, cleaned all the inside of the glass, and gave er a new set of spark plugs.. Next is to give it a good bath and take it on a 60 mile round trip to tailgate at a concert! Crossing my fingers for the trip
61 apache
Clrussell is offline
Old 09-29-2012, 12:52 PM   #4977
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Originally Posted by mud.man.rj View Post
Well took my truck for a run yesterday but the big block was a bit cold and I almost stalled it so sidestepped the clutch a bit and turned at the same time while shooting out a tooth from the side spider gears right thu the rear cover so brought it home and gutted the rear diff. Now I need some info guy's in the know. I have a crappy 73 and up gov. lock posi unit, could put new spiders in but is it worth it, heard they are the "worst" GM diff. Will an Eaton or Auburn posi unit swap in place in the same diff housing (12 bolt). Here are a few pic's. Too much power and tire combo.Haha.
So anyone in the know on the swap.
You found the weak spot!
It is my understanding that an Eaton will go in place of the gov-loc, I have not done it but I was told by a very good mechanic that it would. He also told me that the Eaton is the best to go in a 12 bolt
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline
Old 09-29-2012, 02:34 PM   #4978
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Sorry, mudman
Took the "maiden voyage" of about 20 miles yesterday.
The leak-chasing seemed to work...knock on wood. Still, the radiator weak spot was the trans cooler circuit. It leaked.
So, I've got an external cooler on order and have the cooler lines connected until it comes.
I went to time it today and there is only one TDC mark on the h. balancer. Anyone know a fix for that? Maybe someone sells a "sticker".
I used a hole (that one of the P.O.s must have drilled) in the dash for something to put in a Radio Shack mini-button for the horn.
I'm really not too happy about it, but the hole was already there. And, I *was* sick of sussing out the "beep-beep".
Later for the proper fix.
And, now the brass rat (mouse?) gets a new ride.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-29-2012, 03:06 PM   #4979
shawno72
C/10 junkie
shawno72's Avatar
All set for next Saturday??
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 09-29-2012, 04:13 PM   #4980
magwakeenercew2jh
Ready or not, here we come!!!!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-29-2012, 04:19 PM   #4981
shawno72
C/10 junkie
shawno72's Avatar
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-29-2012, 05:14 PM   #4982
hayhauler71
hayhauler71's Avatar
bought the duel fan to replace the single fan
Fuzzy
hayhauler71 is offline
Old 09-29-2012, 06:07 PM   #4983
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
Bought these today and installed them.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 09-29-2012, 07:22 PM   #4984
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Got out the dies and cleaned up the mangled side mount spare studs the stupid bubbas ruined by using wrong lug nuts , drove it and hauled home another vintage Honda Motocycle , smelled burned oil the whole way there and back - I can't wait to begin overhauling my spare engine .
I wish I were close enough to get that giv. lock rear end ~ I could put it to good use after repairing it as my little 6 Banger engine won't stress it atall .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 09-29-2012, 10:15 PM   #4985
bigguy69
dazed and confused
bigguy69's Avatar
Nice. Where did you get those fans?
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline
Old 09-29-2012, 10:49 PM   #4986
hayhauler71
http://thmotorsports.com/flexalite/f.../i-100406.aspx This was the best price I could find and there is coupon codes for this company
Fuzzy
Old 09-29-2012, 10:59 PM   #4987
PAWS 72
PAWS 72's Avatar
went to the cruise inn tonite and a few of us parked together.Prin's father brought theres out and a friend and mine.
PAWS 72 is offline
Old 09-29-2012, 11:02 PM   #4988
PAWS 72
PAWS 72's Avatar
Andy have you used those in the gauges yet?
PAWS 72 is offline
Old 09-30-2012, 12:03 AM   #4989
jayman68
Fun Stuff
jayman68's Avatar
Sorry, mudman
There should only be 1 TDC mark on the balancer. Does it only have 1 point on the timing cover, or no tab there? There is a tab available.
http://www.summitracing.com/search/?...ng%20tab&dds=1
Or if there is only 1 mark on the timing cover, you could get an advance timing light. Summit does sell timing tape
http://www.summitracing.com/search/P...kr=timing+tape
Good luck.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 09-30-2012, 12:06 AM   #4990
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today!
PAWS 72,
I have the speed hut guages and they have there own led's.
Andy4639 is offline
Old 09-30-2012, 01:10 AM   #4991
Z10
Z10's Avatar
Sorry, mudman
Love the brass mouse! Question: Does he have little brass balls?
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 09-30-2012, 01:14 AM   #4992
magwakeenercew2jh
Only two.
But they're big.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-30-2012, 01:25 AM   #4993
mud.man.rj
mud.man.rj's Avatar
Well searched high and low all day and found a complete Eaton diff. that is supposed to have 3.73's also so should work, will pick it up tomorrow and gut it and see what's up. Hoping it's all good.
mud.man.rj is offline
Old 09-30-2012, 02:22 AM   #4994
BlackedOut67shorty
BlackedOut67shorty's Avatar
Put in my van tilt colum and put the stock 67 steering wheel back on and loving it
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline
Old 09-30-2012, 06:20 PM   #4995
mud.man.rj
mud.man.rj's Avatar
Need parts for my rear diff. So ordered an open carrier for cheap and also a Loc-rite locker for the 12 bolt so will be way better than my Gov lock that blew a tooth and WILL blow again. Now waiting for parts again.
Old 09-30-2012, 08:54 PM   #4996
magwakeenercew2jh
I'm so close, I hate to keep asking for "de-bugging tips" from you all. But I'm going to.
A week ago, before I changed the carb from the Edlebrock to the new Street Demon, I had a little issue with starting. I didn't know if it was spark or gas,
but I smelled the gas, so the bet was flooding. The carb had been on for four years and it had just recently started up...Ran good. but too rich, and the tuning
of the secondaries wasn't responding.
During the time it wasn't firing, I pulled a plug to check for spark, waited until my grandson came home, and got knocked back on my a$$ when it fired up
on the first crank. On seven cyls. ...One I was holding in my hand.
Then I changed out the carb.
Immediately after the install, it started like a pro... after a little dialing in of the cables, electric choke, etc.
Then, yesterday, before the "maiden cruise", she wouldn't start. Tons of cranking. I didn't check for spark. After about 30 minutes of persistent cranking
(and, admittedly, some throttle pumping...then a cautionary, "Hey, no more gas, you jerk!"), she started. Strong and nice.
Went for a 20 mile cruise, and stopped three or four times...restarted perfectly during the stops at the bank, the store, etc. Came home. An hour and a half or two later,
a friend came over. Started her right up to let him hear the exhaust. Ran immediately. And nice.
This morning, I went out to move it into the garage to do some little cosmetic work...No gas on the throttle. "Crank, crank, crank".....
"Oh, SH&$"! Gas...."Crank, crank, crank!" "Double SH*%"! Off with the air cleaner. Gas is squirting big time into the primaries. Choke is open.
Off to the auto pars store. Bought a new Accel HEI coil. Came home and installed it. Fired off immediately.
Now, the problem with that diagnosis effort is that I left it for an hour to get the distributor parts. Given the same time away from the starter
(without getting the $50 Accel coil hit), she may have started right up anyway.
So, unless I re-wiggled and "fixed" an intermittent spark flaw, or something in the HEI coil was fu-bared that I fixed, I still feel the issue is with the gas.
Even though it keeps happening, and did so with a previous carb. As it does now with the new one. (Great carb, though, BTW...Huge difference in all aspects except this one)
Right now, I went out and started it up. Fires off like a champ. My guess is that tomorrow morning, after sitting all night, I'll go out and she'll crank, crank, crank.
Then I'll walk away for 45 minutes. Go back, and she'll fire right up.
Is this magic?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-30-2012, 09:21 PM   #4997
DaHos
DaHos's Avatar
Started building a new one...............Project "Lo-Buck"
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline
Old 09-30-2012, 10:37 PM   #4998
shawno72
C/10 junkie
shawno72's Avatar
Just got back from the C/10 Ranch where Kevin of KevsClassics installed one his very high quality tilts columns. I loved the whole ride home. Thank you Kevin!! Now for that steering wheel change....
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 09-30-2012, 11:37 PM   #4999
jd7
jd7's Avatar
bought a black magic extreme fan ...... will install prolly friday evening. it wont be delivered till thursday
jd7 is offline
Old 10-01-2012, 11:19 AM   #5000
srob67
Installed wheels/tires. Actually yesterday.
srob67 is offline
Closed Thread
