'57 Chevy LS3/4L60E, Thought Id share.
This is a very good customer of mine's car, And one of my favorite cars to work on & test drive
![]() Has had the same owner since May of '57 (2nd owner). Mostly drag raced..Has 94,000 miles. Has had 28 different engines in it since new....Including several 301/327/350 sbc's & 3 LS1's. Still wears its original paint & interior. Original specs... '57 Chevy Sport Coupe. 283 with Two-Fours. Close ratio 3 speed. 8.2" 10 bolt w/ 3:70's. Current drivetrain specs... '11 Camaro LS3... Comp cam(Ill give cam specs later) GMPP CNC ported heads. E38 ECM. 446hp/419ft.lbs. '98 4L60E... 4L65E planets. Sleeved input drum. 9 3-4 clutches Sonnex smart shell HD-2 shift kit. Yank 3000 stall converter. CompuShift controller. '69 Chevelle 12 bolt... Eaton posi carrier (400 lb) OEM 3:73 gears. Moser C-clip axles. Original (re-cored) 3-core radiator, 180 to 210 at all times ![]() Broke 98 LS1 coming out (pulled heads for lifter/cam problem)..... |
Re: '57 Chevy LS3/4L60E, Thought Id share.
LS3 on the stand...
Finished product...
Original sales receipt...
If the two-fours cost $225, I wonder what F.I. cost? |
Cool car, don't see many factory dual 4bbl cars, but I guess that engine is long gone. Almost had a new engine every two years!?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#6 | |
The engine count isnt to bad considering the hardcore 7000 to 8500 rpm drag racing in the last 55 years. |
How many rearends?
That's way cool, not many raced cars look that nice, especially 55yo ones.. I would imagine with that much use it's had to have a rear or two.
Posted via Mobile Device |
Theres a nice body shell and frame on the Little Rock Arkansas Craigs List right now. Got to stop dreaming. Nice car though your taking care of.
![]() Join Date: Aug 2004
I have seen this car at CHris' shop and it is super nice, that LS3 will make it scoot for sure!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
'55 sport coupe.
'05 CTS-V LS6/T56.... Doing a Hydro-Boost (why the master cylinder is off) |
