Old 09-30-2012, 12:40 AM   #1
RPIcka
Fuel Gauge Help Needed (not typical problem)
I've searched and I couldn't find a similar situation. I recently bought a '72 K10 and the fuel gauge would only read from just over 1/4 tank when full and empty when empty. I removed the wire at the sender and grounded it and the gauge went to full, from what I've read doing that should make the gauge read empty?? Could I have a bad sender? Any ideas?
RPIcka is offline   Reply With Quote
Old 09-30-2012, 05:52 AM   #2
JimKshortstep4x4
Re: Fuel Gauge Help Needed (not typical problem)
From your description, I suspect that the resistor on the back of the dash gauge is bad. I would suggest making sure the fuse is good. Disconnect the brown sending wire at the fuse panel and ground the terminal to a known ground on the truck. If the gauge still goes to full then there is a problem with the gauge, possibly the resistor on the back of the gauge.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-30-2012, 11:36 AM   #3
cst350
cst350's Avatar
I recently had a sender problem when installing aftermarket gauges. When I researched this, I found that the sender is actually a ground, but changes its resistance depending on the sender arm. When I bypassed the sender and grounded the wire from the gauge it read full. I then took out my sender, hooked it up and ran the arm up and down to see how the gauge read. It was correct. My problem turned out to be a pin hole in the float.
cst350 is offline   Reply With Quote
Old 09-30-2012, 01:31 PM   #4
GMCJOE
GMCJOE's Avatar
Sounds to me like your sending unit isn't working properly since the gauge reads full grounding it out. Float might be sticking after a certain point. Might be some build up on the sending unit if it sat for a long time. Pull the sending unit out of the tank and see if your float is bad, why it isn't traveling any further than 1/4 of tank, or in general what the issue is.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 09-30-2012, 04:30 PM   #5
AirSpeed
AirSpeed's Avatar
Sounds like your float has a leak, take it out and see if it's full of gas. You should be able to get a new float for a few bucks. Mine did the exact same thing. If it sat empty for a while the gage would work right when I filled the tank, after a day or so the float would slowly fill with gas and the gauge would go down even though the tank was full. I bet it's the float.
AirSpeed is offline   Reply With Quote
Old 09-30-2012, 04:35 PM   #6
AirSpeed
AirSpeed's Avatar
I would be willing to bet your float is leaking. When grounded your gauge should read full, I just tried it on mine and it went all the way to full. Good luck!
Old 09-30-2012, 05:54 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Agree with the float being full of fuel. It seems to be a common problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-30-2012, 08:27 PM   #8
RPIcka
thanks guys, i'll check the float
Old 09-30-2012, 11:12 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Grounding the sender wire takes the sender out of the equation. The gauge should go to empty when the sender wire is grounded. Either the resistor on the back of the gauge is bad like Jim K said or the answer I gave you when you posted this in the electrical forum yesterday is the problem.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-30-2012, 11:16 PM   #10
RPIcka
Can I pick up a new resistor?
