Member
Re: Well I found my water leak.
I sand blasted the rust as best as I could. Then I applied oshpo to the entire area. Am I ok to apply the epoxy or should i prep the metal again with something else? Thanks again!
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
US Army Veteran
![]() Join Date: Nov 2008
Can't say for sure. When I did mine, I applied over bare metal after using Metal Prep for 30 minutes, then thoroughly drying with an air nozzle on my compressor.
The idea was, to have the cleanest surface possible where the putty the putty would stick very well, then sand it smooth and follow up with a few coats of POR-15 for permanent protection. The POR-15 prevents any moisture from getting in. I haven't used phosphorous under POR products, so can't say for sure. I can't imagine the phosphorous would cause any problems. Once the POR-15 is coated over the putty, it's not going anywhere. POR-15 is hard as rock too. One other thing that might help: When I used the putty to fill in rust spots/holes, I'd take two equal parts of the putty (one is a hardener) and roll them in my hands for a few minutes, kneading them every thirty seconds or so. Then I'd "pinch off" little bits at a time and work it into the areas. Don't try to lay the whole ball over the area, just pinch off little pieces of the putty and smooth it into the areas. It's a lot easier to work with that way. Another tip, keep a cup of water handy and stick your finger in it, then smooth the putty out. The putty is water proof, so the water won't hurt it at all, but it does help to smooth it down some.
1972 C10 Highlander - The making of a daily driver Last edited by BruthaMan; 10-01-2012 at 03:27 PM. |
Member
Thanks,. I actually contacted POR directly and they said to coat the entire area first with POR 15, then put the epoxy putty over that. I'll follow your advise and only do small areas at a time. From what i read about it, i should be able to get it smooth enough that i don't have to sand it, then just prime and paint. I'll post some finish pics when i get it done. thanks again for everyone's help.
