#26 | |
![]() Join Date: Feb 2011
Re: Raty 69
Posted via Mobile Device |
#27 | |
Re: Raty 69
#28 |
Re: Raty 69
G'day all, just thought I'd update some progress on my rig. Spoke to an engineer about bagging the truck, going to c notch the rear and cup the LCA's. Might body drop it later. Can't z notch it because will cost to much coin
still pumped as to start it though! so im just finishing off the cab repairs so I can get to work on the chassis and start notching and what not. Here's a few pics of the rust repair progress. Trying to go for the rat rod style of body repairs haha no filler for me!, haha do have more pics but I'll have to find the camera first :P cheers all.![]() ![]() ![]() Posted via Mobile Device Posted via Mobile Device |
#29 |
![]() Join Date: Apr 2008
Re: Raty 69
looks good so far. You will like the new lower stance with the C notch.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#30 |
Re: Raty 69
Cheers Mike, yeah want the notch big enough to lay frame in the rear. props wont get the front laying because of no z notch. will cost to much in engineering it. will lay front crossmember though. well ill try my hardest. cheers
#31 |
Re: Raty 69
gday all, found the camera so i got some more pics of progress. still need to sand the kickpanels but ill do that when the cabs sunny side up. they are not the prettiest repairs but they get the job done. got some primer on the bottom of the cab today so im pritty happy with that. need to top coat it and then i can put it on the chassis and hang the doors and finish off the sills. heres the pics.
#32 |
![]() Join Date: Dec 2011
Re: Raty 69
Looking good buddy , i like the wagon too
BOWTIE OR NO-TIE |
#33 |
Re: Raty 69
Cheers MJ, Cheers Aussie67, Had to sell the wagon because it was haunted haha nah i stilled owed my brother money for it. So it had to go
#34 |
Re: Raty 69
Gday all. Just an Update is all. Got the bottom of the cab seam sealed and Paint it up. Cocked up the bottom when i primed it. Didnt prep it right so the primer was just flaking off when i was seam sealing, so i had to fix that
Moved it out of the shed to the carport. Good to see it not on its back like a $2 hooker haha. Going though some discussion with the landlord (Mum :P) to get my shed concreted so after that ill move the chassis in and start work on that, crossmembers, 4 link and notch etc. Cant bloody wait. Heres some pics.![]() ![]() ![]()
#35 | |
Re: Raty 69
#36 |
Re: Raty 69
just found this thread-looking bloody good!
pleased you have improved your camera skills as the pictures keep us all motivated!! keep up the good work. mark
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
#37 |
Re: Raty 69
So in your bag of tricks do you have plans to make it a right hand drive? looks like a good build and a real learning oppertunity. I'l keep watching
#38 |
Re: Raty 69
Cheers Mark. Yeah I'm getting better at the pics haha Its just good to have a record to.
Thanks MC, nah I'm going to keep it left hook. Make thing interesting. Over here anyways. Yeah im learning lots and I'll just keep learning. I'm having a bloody good time building it. Can't wait to cruze in it. Cheers Posted via Mobile Device |
#39 |
Re: Raty 69
Hi mate,
Is roof/driprail and windscreen apperture rust hard to fix? I am buying a GMC stepside 69' model and it has a bit of rust there. Haven't got a pic of the rust but here is the truck
#40 |
Re: Raty 69
G'day mate. Nice looking rig! Umm not really sure just a matter of getting repair sections and welding them in. I'll pm you my number. You can give us a call to discuss. Maybe even meet up and I'll take a look. Cheers
#41 |
Re: Raty 69
Cheers dude, yeah I haven't looked into patch panels to much, are they pretty accurate or require tweaking?
| Bookmarks |
