Old 05-28-2010, 03:41 PM   #26
Duncan and son
Re: Changing an Ignition Lock Cylinder
Originally Posted by LockDoc View Post
Drilling is just about your only option then. There is another way to do it but it is pretty involved and pretty much only do-able by a locksmith with the correct tools.
LockDoc
If Leon "lockdoc" says a rooster can pull a freight train then you better go find a chain.
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 05-28-2010, 03:41 PM   #27
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
theres ahole in the tubler straighten out the paperclip and push it in the hole and turn key to the far left, ACC position
it should pop out it takes some foolin' with though
John
1999 Toyota Tacoma 4x4
Old 05-28-2010, 05:39 PM   #28
JoeKan
JoeKan's Avatar
Okay, I think I've got the cylinder fixed--good ol WD-40. I'm wanting to tighten the bezel before i put the dash back in.
Oldblue, are you saying to tighten the bezel by tapping it clockwise?
Thanks for the help,
Joe
JoeKan is offline   Reply With Quote
Old 05-28-2010, 05:50 PM   #29
ricks71pu
ricks71pu's Avatar
s/b small hole in cylinder on the left side.
ricks71pu is offline   Reply With Quote
Old 05-28-2010, 06:08 PM   #30
JoeKan
JoeKan's Avatar
Thanks, found it. I'm going to go ahead and replace everything. I've used a pen and paperclip to push in but it doesn't seem to be spring loaded--it's not coming off.
Old 05-28-2010, 07:00 PM   #31
Jwill41
Jwill41's Avatar
turn it to accesory position, put paperclip into hole and push spring while turning farther to the left (counter clockwise) and pull with key.
you can tighten or loosen bezel with screwdirver or you buy a special tool pretty cheap.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 05-28-2010, 08:21 PM   #32
JoeKan
JoeKan's Avatar
I'm stuck on supid today and this thing is kicking my butt! Is it the little pin hole that is right next to the key hole or is it the hole that is on the side of the cylinder thats inside the dash?
Old 05-28-2010, 09:06 PM   #33
Jwill41
Jwill41's Avatar
It is the little pin hole that is right next to the key hole
Old 05-29-2010, 08:58 AM   #34
JoeKan
JoeKan's Avatar
It's not going--how/where can I drill it out?
Old 05-29-2010, 09:40 AM   #35
JoeKan
JoeKan's Avatar
I should also mention that I can spin the whole unit 360 degrees. Help get me unstuck from stupid
Old 05-29-2010, 06:04 PM   #36
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-29-2010, 10:16 PM   #37
LockDoc
The Older Generation
LockDoc's Avatar
Read post #4...
LockDoc
Leon
Old 09-30-2012, 10:47 PM   #38
ChillWinstonC20
ChillWinstonC20's Avatar
An old thread but very helpful. If any of you are still on this forum, thanks. This was not necessarily easy but a whole lot easier thanks to your advice.
ChillWinstonC20 is offline   Reply With Quote
Old 10-01-2012, 09:40 AM   #39
LockDoc
LockDoc's Avatar
Some of us are still around. Glad the thread helped.
LockDoc
Leon
Old 10-01-2012, 09:56 PM   #40
Square_78
Square_78's Avatar
Cool! I just bought a new lock set today and was going to search to see how to do this! Im going to try doing the doors first. My ignition is fine, but just my doors that are almost impossible to lock and unlock. Hopefully there is a thread of swapping out door locks somewhere..
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-01-2012, 11:52 PM   #41
LockDoc
LockDoc's Avatar
Short version is: Remove door handle and window crank & remove door panel. The lock cylinders are held in the door by a spring clip inside the door. The spring clip has a tab that sticks up to have something to grab to remove and replace it. It just slides into grooves at the top & bottom of the lock cylinder but will many times be stuck because of dirt & rust. Spray them with penetrating oil before you try to remove them. Small water pump pliers work good to remove the clips. I recommend wearing gloves to do this because it can be a knuckle buster. If you roll the window down you can take a flashlight and look down inside the door at the back of the glass. You can see the back of the lock cylinder and the clip that holds it in. There is a right and left lock pawl so don't get them mixed up.
Check this thread out also...
http://67-72chevytrucks.com/vboard/s...d.php?t=425488
LockDoc
Leon
Old 10-02-2012, 12:16 AM   #42
Chvy2NV
Great thread!
Chvy2NV is offline   Reply With Quote
Old 10-02-2012, 05:33 AM   #43
Square_78
Square_78's Avatar
Wow thanks LockDoc! Thats exactly what I needed! I see how it works now. Easy.
#teamlongbed
Old 09-23-2014, 05:14 PM   #44
HerrOtto
Will this same method work for a 1961 Chevy C10? There is no accessory position.
Thank you
HerrOtto is offline   Reply With Quote
Old 09-23-2014, 10:00 PM   #45
LockDoc
LockDoc's Avatar
Thank you
If I remember correctly the '61 has a separate start button does it not. If so, you would turn the key to the right to the "on" position then insert the straightened wire or paper clip to depress the retaining pin. Then turn the key farther to the right to remove the cylinder. This is the opposite direction from the '67-'72's. I would unhook the battery before doing this.
Any problems let us know.
LockDoc
Leon
Old 09-24-2014, 09:22 AM   #46
HerrOtto
Lockdoc, thanks for the reply. There is no separate start button but as soon as my new ignition lock cylinder arrives, I will give your instructions a try.
Old 09-24-2014, 08:54 PM   #47
LockDoc
LockDoc's Avatar
If there is a start position in the switch then it would remove just like the '67-'72's....
LockDoc
Leon
Old 09-24-2014, 09:21 PM   #48
HerrOtto
OK, thanks. I will let you know how it goes.
Old 10-02-2014, 02:10 PM   #49
HerrOtto
The lock cylinder went in with very little problem. You stick the paper clip in the hole and turn the cylinder it to the left while pulling on the cylinder. It will eventually work its way out. Place the new cylinder in the same position as the old cylinder came out and turn to the right. Thanks for the help.
Old 10-02-2014, 03:02 PM   #50
LockDoc
LockDoc's Avatar
No problem on the help. Technically you should turn the cylinder all the way to the left "Before" you insert the paper clip and push the spring loaded pin down, then it should turn to the left a little more and pull out.
LockDoc
Leon
