09-30-2012, 12:20 PM | #1 |
74 booster in my 67
i removed everything from a 74, pedal, steering column, booster, m/c, lines & complete suspension. i now have the complete 74 suspension & cradle installed in my 67 my search says the power booster will fit with a new hole & some cutting has anyone done this swap & will the 74 pedal fit? thanks to all
1990 chevy 4x4 with a 1940 IHC body |
10-01-2012, 03:50 PM | #2 |
67-72 parts collector,…
Re: 74 booster in my 67
You don't need the 74 pedal.
Just connect the '74 booster rod to your existing 67 pedal. When I did this swap back in the 80's,.. I had to lengthen the brake pedal push rod also.
10-01-2012, 06:13 PM | #3 |
ty lolife99 i thought by using the 74 pedal all wood work in unison u say extend the rod do u mean add something to it or screw it out to make it longer? also by usin the 74 pedal if it fits i would have the larger "brake pedal" as mine is a standard thanks again
