Tailgate mounting help required
As you know I posted some pics and info on my tailgate, anyway I tried mounting it on weekend and cant seem to find the items required to mount it on the bottom that will allow the tailgate to go up/down
I suspect it needs to be like a spring loaded round bar to allow it to be pushed in to allow mounting of the tailgate... Thanks
------------------------------------------------------ ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560 |
![]() Join Date: Feb 2011
Re: Tailgate mounting help required
Bolt up one hinge,put on tail gate. Put hinge on other side and bolt up. No spring that I'm aware of.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
Thanks Daddy Brim,
But mine has holes on both ends as if a rod suppose to go inside.... Looking at your gate it sort of slots from the top mine does not... I can take close up photos to show you.... ![]()
sounds like someone may have played with your tail gate previously, but the pictures that daddy brim show are correct, no springs or rods, just a cap on each side that it rotates on
1969 c-10 short bed stepside - work in progress ![]() |
#5 | |
ah i just went and looked at your other post, sorry i didn't realize your tailgate isnt the stock one for the US atleast so at that point i am unsure of how it would mount, sorry.
when these trucks where imported to mexico they sent them over with out the beds so they would only get charged export/import fees on parts rather than a whole vehicle, and then they put on a bed they made in mexico which was different. so i would suspect they did something similar to canada. unfortunately there really isnt a lot of info on those, but everything else about the truck should be the same as the US
Got me looking now! Mine is put on with a big allen key bolt......
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
the US stepside beds are done with a round slug with a tapped hole in the middle, which you put into the tailgate and then put a bolt in from the outside. they give you a whole at the bottom of the gate to attempt to hold the slug in place while bolting to it. that one is a pita.
#10 | |
i dont have any pictures myself of them, but lmc has a somewhat decent pictures of what im talking about
yep thats the one. Just have a nice black hardened steel allen key bolt in there.
Keeps the bastards from walking away with the tailgate easy pesy. |
Guys here are pictures of my tailgate and mounting section on the truck, as you can see on the truck side I have added 2 white lines showing the ridge it has. I just dont see how these got mounted
#14 | |
Looks like there might be a thick layer of "Bondo" on top of the bolts.. Hard to tell from the pictures.. but it sure looks like it..
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
#15 |
Mark, that is definitely not bondo, its actual factory welded metal........
#16 | |
I apologize; I did not read your thread in depth enough. Below are pictures of how the 67-71 USA fleetside attaches. Good luck with your build. ![]() ![]() ![]() ![]() Have a great day..
#17 |
No worries Mark.
I see there are 2 holes below that big hole, do you think I would need a bracket down there to mount the tailgate? What confuses me is I do not know what that big hole is for....
#18 |
Hi ZUBZ, Dan 67c10rustbuket contacted me via PM about this post, since your C/10 seems to have similar tailgates like ours (Argentina).
I have no information about in my books, and mine is a C/30 flatbed, so no tailgate, but a friend of mine owns a 76 pickup and he help me to get you a few pictures of the part used in Argentina. You can see it has a big hole on top, and two small holes on the bottom. I hope this helps.
1970 Chevrolet C/30 1972 Chevy Nova SS Coupe 1977 Chevrolet C/50 1995 Chevrolet P30 - Grumman Olson Route Star |
#19 | |
#20 |
Sorry, no part number. I guess you will have to do it yourself.
Even here in Argentina this part is impossible to find.
#21 | |
Any help would be greatly appreciated.
#22 |
Sure, no problem. Next time I see my budy I'll do it and post the info right here.
#23 |
German AC, thanks, you are a good man.
#24 |
HOPE THIS HELPS
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
#25 |
Thanks 77 for the info, however my question is more relating to the template of the hinge, I showed the picture to an engineer but he said if I can get a template of the hinge and some measurements it will be a lot easier to feed this into his computer program so that we can fabricate the item.
