Old 10-02-2012, 01:59 PM   #1
65truckowner
65truckowner's Avatar
1965 chevy c10 question
I am new to this forum but not chevy trucks 64-66 anyway I just bought a 65 big back glass to restore and someone has converted this truck to leaf springs in the back and done a decent job. My question is I am building this truck to sell should I leave the leafs or go back to the coils? It has also been converted to 5 lugs and disk brakes on the front. If I go back to orginal will the axles fit the stock rearend? Will the leaf springs hurt the value of the truck once restored? I sold one back in the spring I restored it was all orginal except the wheel and tires and exhaust.
65truckowner is offline   Reply With Quote
Old 10-02-2012, 02:42 PM   #2
1963c-10
1963c-10's Avatar
Re: 1965 chevy c10 question
If your going for 100% original, id swap back. If the truck is going to be a driver and not worried about the original aspect, Id leave the leaf springs in. As for the axles...I cant answer that one. Try Capt. Fab, he can be found here. Hes a guru with the rear diffs. Love to see some pics of both trucks also if you can.
1964 Short bed trailer
Old 10-02-2012, 03:32 PM   #3
65truckowner
Here is the one I restored and I will get pictures of the other one soon. I am not really worried about it being orginal so I might leave the leafs alone.
Old 10-02-2012, 03:58 PM   #4
1963c-10
1963c-10's Avatar
Great looking truck you had.... The fun part is starting over again. As long as the leafs are in good shape I'd leave them in also. Be a bit of work to convert to coils, but can be done. The big back window is a desireable option.
Old 10-02-2012, 05:14 PM   #5
faribran
i vote to leave the leafs alone.. if they are in good working condition.... but as they all say.. "its truly your call to make"
faribran is offline   Reply With Quote
Old 10-02-2012, 07:21 PM   #6
65truckowner
This one is next. I am going back with the maroon and white top and all new chrome. I will probably just keep the leaf springs.
Old 10-02-2012, 08:30 PM   #7
gimmy 64
can you tell someone changed to the leafs because they were an option when buying new and standard on gmc.
gimmy 64 is offline   Reply With Quote
Old 10-02-2012, 09:07 PM   #8
65truckowner
These have been added. It still has the mounts for the coil set up.
Old 10-02-2012, 10:13 PM   #9
MARTYZ
MARTYZ's Avatar
Nothing wrong with leaf springs, but if you are doing a retoration the coils do offer alot nicer ride , i my opinion
MARTYZ is offline   Reply With Quote
Old 10-03-2012, 10:10 AM   #10
faribran
sure appears to be a NICE starting point............keep us posted as you go along.
Old 10-03-2012, 10:22 AM   #11
65truckowner
Hope to get it in the shop this week and start on it the first of next.
Old 10-03-2012, 11:00 AM   #12
glos55
glos55's Avatar
Looks to be fairly solid....keep us posted on the progress!!
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
Old 10-04-2012, 06:37 PM   #13
65truckowner
I moved the truck to the shop today and was looking at the chrome down the side of the truck and some of it looks good. The other truck I bought new chrome but is there a way to clean the chrome I have?
Old 10-04-2012, 11:36 PM   #14
Captainfab
60-66 Nut
It is not exactly 'chrome', it is polished aluminum. To clean it up you will have to strip the clear anodizing off and polish the aluminum. Oven cleaner works good to strip the anodizing.
Old 10-17-2012, 05:25 PM   #15
65truckowner
Here is a picture of the leaf spring set up. The only thing is for some reason the passenger side is 3/4 of an inch lower not sure if it is the springs or what
Old 10-17-2012, 05:57 PM   #16
Clyde65
Clyde65's Avatar
those shocks arent doing ANY good right there!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-17-2012, 06:19 PM   #17
65truckowner
Yeah I know Not sure what I am going to do about them.
Old 11-05-2012, 07:13 PM   #18
65truckowner
Ok I removed the leafs today. The truck was sitting a good 1/2 inch lower on the passengers side.I removed the rearend so I could measure a little better and one of the spring hangers was lower than the other. So instead of trying to fix it I am going to put the orginal set up back under the truck.Also the shockes were not working with this setup. I need a set of axles with five lug instead of the six so it will match the front. I am leaving the disk brake set up in the front. Can I buy a five lug axle that will fit the 66 rearend I am putting under it? If yes where?
Old 11-06-2012, 01:39 AM   #19
Captainfab
60-66 Nut
You can get them from Summit Racing, Moser, CPP, ECE, LMC, and I'm sure there are a couple other sources.
Old 11-06-2012, 08:36 AM   #20
65truckowner
Thanks. I will check them out.
Old 11-06-2012, 08:49 AM   #21
65truckowner
All I could find in my lmc book for 65 was 6 lug.
Old 11-06-2012, 09:34 AM   #22
Clyde65
Clyde65's Avatar
summitracing.com
Clyde65
Rebuild of Clyde
support our troops!
Old 11-06-2012, 12:32 PM   #23
kieth
kieth's Avatar
I just pulled the axles and had them drilled for 5 x 5 cost about $100.00 plus new studs and brake drums.......beat the heck out of 500.00 Kieth
kieth is offline   Reply With Quote
Old 11-06-2012, 12:51 PM   #24
1963c-10
1963c-10's Avatar
To clean & polish the aluminum...make sure that the oven cleaner has sodium hydroxide in it or it will not work. Its listed on the front or back label if it has it.
