Old 10-04-2012, 11:39 AM   #1426
NONHOG
NONHOG's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Originally Posted by 76C10Stepside View Post
some perspective on just how easy his project is compared to some of the crazy stuff going on out there!
true words, right there. I just change the part where you said "his project" to "my projects"
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 10-05-2012, 12:02 AM   #1427
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by nuke1 View Post
Very nicely done good sir! I like your style and techniques. the annealing and sand trick worked great. Those pedals in you car sure look familiear. I believe I put a set of those in the "back burner" camaro I did. hehe.
Thanks Nuke! Those pedals are factory S2000 (slightly mod'ed).
Great stuff as usual, FF! I need to send my kid a link to your thread. He's struggling with his first car restoration and needs inspiration, and some perspective on just how easy his project is compared to some of the crazy stuff going on out there!
You guys might expect my 13yo to be turnin wrenches with the best of em, be he has zero motivation to play with that Squareback. I'm more interested in it than he is. Maybe he's too young to see the value it will bring him ...a cool ride when he's 16, c'mon!
So you're son is not alone. It's easy to get overwhelmed when there are countless unknowns on the road ahead, but as he checks off each task confidence and momentum will build.
You tweak on some cool stuff and not for the novice either. Just need you do get rid of that lame Amazon...
Frizzle Fry is offline   Reply With Quote
Old 10-05-2012, 05:39 PM   #1428
watahyahknow
watahyahknow's Avatar
he prollt start getting interested one week before his 16th birthday , and knowing you a little the only thing left is to buff up the paint a little
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-06-2012, 07:31 PM   #1429
Frizzle Fry
Knowing me..? take a look at when I started this project.
Old 10-06-2012, 10:41 PM   #1430
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Damn Mike, has it really been 3 years?
screamin_c10 is offline   Reply With Quote
Old 10-07-2012, 12:55 AM   #1431
Frizzle Fry
I know... no more messing around! I'm getting ready to do a fully mocked up shake-down drive!!!
Old 10-09-2012, 02:04 AM   #1432
76C10Stepside
76C10Stepside's Avatar
Get it done already!
76C10Stepside is offline   Reply With Quote
Old 10-12-2012, 02:39 AM   #1433
Sub-versive
Boss Hogg
Sub-versive's Avatar
And take a few of us for a cruise/drift/etc.
And then get back to work on the "Tahoe". *cough* *cough*
RIP El Jay
2015 Subaru Outback 3.6R Limited
2002 Chevy Trailblazer LS 2WD
Originally Posted by dammitmitchell View Post
....wear your adult diaper when you go out to play.
Originally Posted by Shane View Post
I am tard.
Do, or do not, there is no try
Sub-versive is offline   Reply With Quote
Old 10-12-2012, 01:46 PM   #1434
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I wanna go for a ride!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-13-2012, 12:38 PM   #1435
nuke1
nuke1's Avatar
Waiting..........................................
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-13-2012, 02:01 PM   #1436
Frizzle Fry
Bleed brakes, install wheels and seat; drive! But the rear brakes don't want to bleed! Already replaced mc. Using vac pump. Wish me luck!
Old 10-13-2012, 04:11 PM   #1437
watahyahknow
maibe it helps to jack the rear up as far as it wants to go
makes the bends that are above the bleednipples go below it
Old 10-13-2012, 04:29 PM   #1438
71swb4x4
71swb4x4's Avatar
You don't need back brakes with those huge front discs. Get in it and drive, we are waiting!!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-13-2012, 09:40 PM   #1439
dammitmitchell
the pollock
dammitmitchell's Avatar
Id double check any flare fitting... they have a tendency to suck air with the mighty vac, but work semi allright under pedal...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 10-13-2012, 10:38 PM   #1440
Frizzle Fry
Well, it seems there may be a fundamental design flaw in mounting the MC rotated 90*. I can't get good pedal pressure at all. Even with the rear circuit port capped and good solid fluid streams at both front calipers.
The last option to try before addressing the MC (either make an adapter to turn it or buy a different MC all together) will be to try a pressure bleeder...
Old 10-14-2012, 12:20 AM   #1441
nuke1
nuke1's Avatar
Sucky, my solution.......
You have 3 options: A) No brakes needed, just be a great driver and never stop
B) fred flintstone the car, hole through the floor and some good work boots
C) E-brake only
I think those are some fine options and that is what should be done, you have some very impatient ppl here waiting, inc me!!! hehe
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 10-14-2012, 02:57 AM   #1442
Frizzle Fry
I do have a good functioning turning brake and skills to use it
Old 10-15-2012, 01:02 PM   #1443
69gmcc10
69gmcc10's Avatar
cap the prop valve to the rear and just run the E brake! That sounds like a little excitement every day.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-15-2012, 07:59 PM   #1444
Frizzle Fry
Not messin around. Got this on the way...
Old 10-16-2012, 07:55 AM   #1445
Zoomin
Man of Mini-Talents
Zoomin's Avatar
That should take care of it.
Zoomin is offline   Reply With Quote
Old 10-17-2012, 06:48 PM   #1446
screamin_c10
Sweet!
Old 10-17-2012, 08:29 PM   #1447
Frizzle Fry
UPS Status = Delivered
Old 10-17-2012, 08:40 PM   #1448
nuke1
nuke1's Avatar
Good man! I like parts. They are like little packages from heaven. Hehe
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 10-19-2012, 03:11 AM   #1449
Frizzle Fry
I know man. Sometimes they show up for days.
Let's get caught up to present:
Cooling lines installed. Some of the gates shrink clamps too.
The S2000 MC that ultimately didn't work due to failure to bleed:
Had set up some 90* fittings and a bracket for the reservoir to mount in this orientation:
Clutch slave cylinder flex line bracket:
Key oreintation flipper 180*
Reduced width and primered (no pic of it installed...) :
Removed broken bolt from rear:
Success:
Wilwood MC installed and BLED!!! (FYI the nut on the firewall above is for the fuse panel and will be relocated to the inside/welded in before paint)
Rack ready to go in:
...and back on her wheels:
Just waiting for a clear day now... Better/outside pics to come!
Old 10-19-2012, 09:04 AM   #1450
theastronaut
theastronaut's Avatar
Coolest thread on the site, definitely the one I'm watching the closest! Awesome work on everything you've done to it!! Anxious to see it out and driving!
theastronaut is offline   Reply With Quote
