Re: What E.T with this set up?
This engine if done right should net you about 500hp and up with those heads. You may want to check the cam and double check everything else. I know there are cams out there that will produce as much power while being drivable on the street
What's your gearing? I imagine with 373 gears and stick rubber mid 11 sec 1/4 mile times will easy to get. Make sure you have Caltracs or a four link for planting the tires and keep the tailgate up Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
| Bookmarks |
