Old 09-15-2012, 02:18 PM   #926
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by XxCHEVYMANxX View Post
Maybe a dumb question, but I read an earlier post that had to do with centering the front wheel in the fender opening. Is this done with the A arms your installing? and is just the lower needed to accomplish this? I'm still learning.
Yes, the Porterbuilt control arms I'm installing will move the lower ball joint forward 1", helping to center the front wheels in the wheel arch as well as adding some much needed caster. They offer uppers as well, but they will work as lowers only. The front wheels should move forward 1/2" or more...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-15-2012, 02:33 PM   #927
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I need to get around to this....bought tubular uppers but need to add the lowers. Part of me has been holding off tho...for a complete IFS from Scott's, Jim Meyer Racing, P.B., or others. Want coil over with rack and pinion front setup...IFS best way to get there I think.
Course its like my appetite....eyes always bigger then my.....................wallet!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-15-2012, 09:12 PM   #928
gringoloco
A guy with a truck
gringoloco's Avatar
I am with ya on that one--had my heart set on another Dropmember, just couldn't put together the scratch right now. Maybe an assembled pic of the lowers will help you decide
-Chris
Old 09-15-2012, 09:32 PM   #929
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
I love the current look wouldn't change a thing, drive and enjoy it
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 09-16-2012, 09:44 AM   #930
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! The look shouldn't change much with the coming mods, just make it more fun to drive
-Chris
Old 09-16-2012, 09:56 AM   #931
big_al_71
big_al_71's Avatar
this truck looks terrific!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-16-2012, 03:18 PM   #932
gringoloco
A guy with a truck
gringoloco's Avatar
Hey thanks a lot man! Likewise--love your truck, just don't have that kind of budget
-Chris
Old 09-16-2012, 03:21 PM   #933
Bennett68C10
Bennett68C10's Avatar
Hurry up and get these control arms installed, we want some more pics
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-16-2012, 06:38 PM   #934
gringoloco
A guy with a truck
gringoloco's Avatar
Slight pause while I replenish the truck fund for the next upgrade
-Chris
Old 09-16-2012, 08:19 PM   #935
68GMCCustom
and I was in recovery...then you just had to go and do that....didn't you!
Now I got the "project parts blues" twitch again.
Kurt -
Old 09-17-2012, 07:55 AM   #936
gringoloco
A guy with a truck
gringoloco's Avatar
Just remember, you can quit anytime you want
-Chris
Old 10-06-2012, 11:23 PM   #937
suspect
suspect's Avatar
Cool truck. Another good build thread I can use for reference.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 10-10-2012, 08:27 AM   #938
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, man. Looks like you've got it under control- nice build
-Chris
Old 10-13-2012, 06:39 PM   #939
gringoloco
A guy with a truck
gringoloco's Avatar
I'm back in town and have a short break in the action before work picks back up again, so I've been working on getting the Bilsteins mounted up. Since I'm mounting them in other than the stock suspension setup, they're requiring a little bit of custom work.
First, I decided I needed to raise the upper mounting points, both front and rear, to keep the shock from bottoming out and to position them closer to their center-stroke 'sweet spot' at ride height. Out back, I decided I would modify my existing mounts by re-drilling the ECE relocator. This gives me just over an inch of extra travel and only adds around 2* of lean, based on my limited geometric/trigonometric calculations--luckily my wife's an engineer They ended up at just over 15" extended at ride height, which is just about in the middle of their travel. Perfect.
After mounting them up, I took it for a drive, and WOW! I've heard good things about Bilsteins, but never experienced them first-hand. The truck feels completely different now; much softer, but more controlled feeling ride. I honestly was not expecting this much of a difference just from swapping shocks, much less the rears only. It is quieter, smoother, and and more composed. Money WELL spent. I'm anxious to see what the fronts do for the overall feel of the truck.
-Chris
Old 10-13-2012, 07:06 PM   #940
gringoloco
A guy with a truck
gringoloco's Avatar
As for the fronts, I will be using the CPP/POL style upper relocators, which require loop style mounting instead of the frame-mounted stud. The problem with using the Bilsteins with these is that the shocks come with the upper stud permanently attached. No biggie there, as I just cut the end off and pressed them out, but had to special order bushings to fit the width of the mount.
The lower end had to be modified as well, due to the PB arms using a 5/8" stud instead of the stock arms 1/2" bolt. I originally thought I would just press the metal sleeve out of the bushing, but they were permanently bonded, so I picked up a set of Energy Suspension hourglass bushings and pressed them in their place. Worked perfectly--now I'm just waiting for the upper bushings to come in...
-Chris
Old 10-13-2012, 08:01 PM   #941
CC69Rat
CC69Rat's Avatar
Bilstiens kick major a55.. one of the best out there IMO
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 10-13-2012, 10:01 PM   #942
gringoloco
A guy with a truck
gringoloco's Avatar
No doubt! I'm a believer, now. This answers your question on if they'll work with a 6" drop, too
-Chris
Old 10-14-2012, 09:47 AM   #943
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Nice fab work, and install. the shocks, just goes to show sometimes it pays to spring for the good stuff ! looks like it's time to throw out my abacus and brush up on my trigonometrics. lol
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 10-14-2012, 10:43 AM   #944
mcbassin
Still Learning
mcbassin's Avatar
Keep up the good work. Still taking notes watching and learning as you go.
Old 10-14-2012, 11:09 AM   #945
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! This is definitely one of those times. Man, if not for my wife, I'd still be scratching my head
Hah! I'm still learning, too Who knew shocks could be such a pain? This is what I get for trying to be different, but so far, the extra money and effort is paying off.
I'm still chipping away at it, but don't want to incapacitate the truck for too long, so the upgrades are getting broken down into manageable chunks. I'm thinking probably front C5 brakes next, since I can swap them out without affecting too much else (master cylinder, prop valve, lines, etc). The rear sway bar needs to wait 'til after I finalize rear ride height, which has to wait and see where the front ends up after the LCA install. I'll also prolly do the front shocks at that time to make sure my upper mounts line up well with the PB units. Rear discs will come somewhere in there after the fronts, which will be a pretty big job since I have to remove axles and swap out the master cylinder and prop valve in the process...
-Chris
Old 10-14-2012, 11:24 AM   #946
lolife99
67-72 parts collector,…
lolife99's Avatar
Don't remove the rear axles unless you need to replace seals and bearings.
I have seen alot of people just cut the backing plates in half and remove them,... without taking the axles out.
(what are you going to do with the old backing plates anyway?)
Keith
Convert to disc brakes.
Old 10-14-2012, 12:06 PM   #947
Painter D
Painter D's Avatar
Good job keep at it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 10-14-2012, 01:16 PM   #948
big_al_71
big_al_71's Avatar
That's great thinking out of the box I learn from guys like you every day
Old 10-14-2012, 02:27 PM   #949
54Caddy
GM Addicted
54Caddy's Avatar
WOW!! I just went threw your whole 38 pages. Nice truck man. Been wondering what you were building when i bought those parts off of you. Nice truck for sure.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 10-14-2012, 03:27 PM   #950
gringoloco
A guy with a truck
gringoloco's Avatar
Good point, thanks. The bearings/seals are good in this axle and the backing plates will just get tossed in the green monster--just gotta figure a way to do it cleanly without damaging anything else in the process...
Thanks! Plugging away...
Thanks! Just doing what I can to make these out-of-the-ordinary and not intended to be done together mods work in harmony--all while doing it 'right' and saving some coin in the process. The planning/figuring is half of the fun
Hey, thanks, man Glad you were able to use the tie-rods
-Chris
