Old 10-06-2012, 09:31 AM   #1
Bairs71
Bairs71's Avatar
Cool ?s on the low with out the bag.
Ok I have a 71 and was wondering is spindles and springs it or is there another way to go power with out cutting or heating the springs. And what size of tires are ppl running on there 15' rallys ... Thanks and keep it up this is an awesome site.. And lots of sweet trucks here...
Bairs71 is offline   Reply With Quote
Old 10-06-2012, 09:58 AM   #2
leftybass209
leftybass209's Avatar
Re: ?s on the low with out the bag.
You can get a custom cross member that will add additional clearance. Porterbuilt or some other companies have parts. Obviously you can only go so low before the lower a arms, cross member, and oil pan are dangerously close to the ground. How much further are you wanting to go?
leftybass209 is offline   Reply With Quote
Old 10-06-2012, 11:30 AM   #3
Bairs71
Bairs71's Avatar
Not to sure I guess ill come across that when I cross it. I guess when I figure out what tire to run ill see how much further ill go but might be enough with the right tire.. I have the 8' wide rallys I'm getting ready now I'm just not sure if I want to go 50 or 55...
Old 10-06-2012, 02:45 PM   #4
oldschool18
oldschool18's Avatar
If you go with smaller tires and you want to go lower you might run into being to low. If you think you still are going to have to lower it more then you might want to do springs all the way around or springs in the rear and spindles up front. lowering springs and spindles are prob the best ride quality your going to get over cutting or heating springs. what and size rims and tires are on it in the first pic, and how much lower do you want to go off of that? And nice truck always nice to see more people from PA
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 10-06-2012, 02:51 PM   #5
Bairs71
Bairs71's Avatar
Well I already heated the fronts and rears but I want to do a 2 inch spindal and a 3 inch spring in the front. and a 5 inch spring in the rear. I am gonna run the 15x8 rallys cause I hate the other wheels. and what's on there now are 31x10.50x15 and the fronts are 215x75x15. So just by changing my tire size is going to make a huge diff.. but I can't seem to figure out what tire I wanna run.. I was thinking a 245-50-15. But there hard to find...
Old 10-06-2012, 02:54 PM   #6
50bomb
50bomb's Avatar
I really like the two tone on your truck!
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 10-06-2012, 03:04 PM   #7
Bairs71
Bairs71's Avatar
Thanks...
Old 10-06-2012, 05:40 PM   #8
oldschool18
stay away from the 245's there way to wide for you if your going to slam the truck, i would go with a 205 then there is less of a chance the tread will be tearing up your wheel wells
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 10-06-2012, 06:28 PM   #9
Square_78
Square_78's Avatar
I have a 215/70R15 on the front of mine with an 8" wheel. That would have been about the stock size. Its 27" in diameter and fills the wheel well perfect. I think mine came down about 6 inches in front, maybe 6.25". Some guys even run a 215/60R15 and they are laying right on the ground with bags. Its a little too small (at ride height) for my taste, but looks good when aired down. Heres mine...
First two pics are mine. 215/70r15 (27" tall) before and after lowering. This is about as low (static) as I would go and still be able to drive it around. I have long tube headers on it and they are about 2" off the ground. Crossmember is about 4.5" off the ground. Third pic isnt mine, but its a member truck here. He is running 215/60r15 (25.2" tall) I believe and he is on bags.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-06-2012, 06:41 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
5.5/7.5 drop.
215/70's on 7" rallys and 275/60's on 8" rallys.
Front:
2.5" spindle
3" drop springs
drop shocks
Rear:
6" drop springs
1.5 drop block
rear shock relocators
drop shocks
Super Track bar
Bolt in c-notch
Keith
Convert to disc brakes.
Old 10-06-2012, 08:00 PM   #11
Bairs71
Bairs71's Avatar
@ lolife where did u find a 2.5 spindle for the front and a 6 inch spring in the rear. And what is a 1.5 inch block with out leafs ... Truck looks good.. And that's how I want mine to sit as well...
Old 10-06-2012, 08:13 PM   #12
lolife99
lolife99's Avatar
Everyone sells 2.5" spindles.
ECE, McGaughy's, Western Chassis, Performance Online, etc.
Early Classic Enterprises sells 6" rear springs.
I made my lowering blocks, but you can buy them here:
http://www.stockcarproducts.com/trkarm1.htm
The front a-arms are really close to the ground with this combo.
Keith
Old 10-06-2012, 08:24 PM   #13
Bairs71
Bairs71's Avatar
I have drug worse on the ground. Lol.. I used to have a bagged s-10 no blocks just from and exaughst would drag when bagged out.. Thanks for the info everyone.. You have all been a big help... I'm glad I went C-10 and older.. I love it.. Thanks again for all ur help... Great site...
Old 10-07-2012, 07:25 AM   #14
Square_78
Square_78's Avatar
5.5/7.5 drop.
Looks good to me! Yours has about the same stance as mine, and the front looks about the same height. I dont have a notch in the back yet. Mine is just bottomed out on the bump stops right now. I'll do my notch in the springtime and add some 2" blocks.
#teamlongbed
Old 10-07-2012, 10:16 AM   #15
lolife99
lolife99's Avatar
2" blocks are fine for 20's.
If you have 15" wheels,... I wouldn't go with more than a 1.5" block, or you will have scrubline issues.
Keith
