Old 10-07-2012, 05:59 PM   #1
Leftlane
Moving cab and bed?
Het guys,
I'm working on my '71 sbfs.
I've got the bed off and sitting on milk crates in the shop, but its taking up a lot of space.
Id like to stand it up on the front edges, which I've seen done a lot.
I'm worried about bending the front lower edges when I tilt it up.
Are those corners strong enough for that, or will I need to lift it completely and not pivot on those corners?
Sorta have the same question about rolling the cab onto its back.
Will the corners bend, or are they strong enough to roll the cab back on?
It's just me and a buddy doing the moving.
If they need to be completely lifted, I'll need to line up more help.
Thanks,
Keith
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 10-07-2012, 06:03 PM   #2
mr48chev
mr48chev's Avatar
Re: Moving cab and bed?
I'd get more help so you can lift it up and set it down rather than rolling it up and risking bending the corners. My luck has always been that if I try to do something and don't have enough help things go wrong in a hurry.
Old 10-07-2012, 06:11 PM   #3
c10srule
c10srule's Avatar
it will all bend, if the bed was upside down itd be fine, 4 guys should be able to do it but 6 would be great
c10srule is offline   Reply With Quote
Old 10-07-2012, 08:16 PM   #4
Leftlane
That's kinda what I was afraid of.
Guess ill have to make more friends!
I was wanting to get the frame out for blasting next weekend.
Old 10-07-2012, 09:01 PM   #5
RPBurris
RPBurris's Avatar
I have had my 8' fleetside bed standing on its nose for over a year. Moved a few times with a forklift just by tilting it on the forks with me and another guy. Granted this is not a finished bed but they have a lot of steel in them and are quite sturdy. Just make sure you a tilting it evenly and not tilting from the bottom. The top side of the box is strongest.
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 10-07-2012, 10:10 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Why not pick up a couple of furniture dollies and join them together? You could stand the nose of the bed on top of the dollies and be able to roll it around. But, you'd also want to have some thing to tie it to, to keep it from being able to fall on top of someone. Maybe tap into the studs of your shop area. The structure wouldn't be supporting the bed, just serving as a restraint point.
Member Nr. 2770
