SWBs: 67 2x4, 67 4x4, 70 4x4
Vent Window Rebuild or Replace
I have heard that the aftermarket, (Goodmark) vent windows leak air or whistle after being installed.
I have rebuilt a pair of 55 vent windows and also know that it is not very easy. Does anyone have any feedback regarding rebuilding verus new? I have not looked yet, but is one rebuild kit better than another? Thanks in advance!
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
Re: Vent Window Rebuild or Replace
I just rebuilt one the other day. It went good, only had a little bit of a challange with the rivits on the straight rubber piece.
There was another post some time ago that recommended not drilling out the pivot rivit and drilling out the rivit in the channel instead. I decided to drill the pivot and replace it with a stainless screw and nylock nut. The whole project went off fairly well. All said and done, I was out about $40 for the pair. That is a hell of a lot cheaper than the new/rebuilt ones that I have seen for sale. |
![]() Join Date: Nov 2006
Tim christian sells the rebuild parts and new rivets with the tool to do it very reasonable. Parts are very hi-quality and tim is great to work with. Fyi
bob
I BELIEVE IN JOHN 3:16 |
Moderator
![]() Join Date: May 2007
Replace the rubber. Use pop rivets instead of the original style.. Easy job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
throw them away and buy them new from classic industries, pricey but worth it . 199.99 a pc. my 2 cents.
http://i648.photobucket.com/albums/u...Picture008.jpg |
Actually all the vent windows made are from Counterparts. Goodmark and all the other Sellers including us do not make them. The biggest complaint we have is that if not waxed often enough. The chrome rusts real fast. At least here on the coast. Maybe not in a dry climate. I personally like rebuilding them and rechroming.
We retail and wholesale everything needed to rebuild Vent windows even a quality rivet tool. See pics. Need the rivets we will sell you one or 1000 ![]() Last edited by mbgmike; 09-09-2009 at 06:36 PM. |
Gotta luv the forum.
I guess I will rebuild them. Even found an article about doing it in Car Craft........ I need to come to your place Mike. Have heard nothing but good comments.
![]() Join Date: Jul 2004
We used counter parts rubber on one set, fit like crap. Had to redo, next time we got rubber from Classic Parts of America and they fit fine, we're finding not all rubber pieces are created equal, check with the board members who sell here, they know what brands work too. Too much of a pain to do twice.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
[QUOTE=Conroe trucker;3510505]Gotta luv the forum.
I guess I will rebuild them. Even found an article about doing it in Car Craft........ Do you have a link to that article? Thanks |
454 MAKES IT ROAR
Yeah, linky..!!
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
No to hijack, but what is the difference with the '67 vent windows?
![]() Join Date: Apr 2005
[quote=Ratone71;4135081]+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Sofa King Crazy!!
There is a step by step in the forum FAQs. Did mine and it was pretty easy. If you drill out every rivet it makes it much easier, you just have to keep the frame straight, it will bend easily.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
Rebuilding them is easy, as mentioned before, remove all the rivets, it makes the job much easier. I learned that it helps alot to lube the rubber that pops into the frame, the first time I rebuilt a pair I didn't think to lube the rubber and it was a pain in the anus! If you take your time they will look just as good as new. I used a rivet gun for the pivot.
#15 |
Moderator
Easier to remove the bracket that the pivot attaches to, rather than the pivot rivet itself. The two rivets attaching the bracket can be drilled and replaced with pop rivets.
#16 |
Man of Mini-Talents
Last week I saw this thread and skimmed it thinking it might come in handy and sure enough. I got one side done today, and the other has a rusted channel. I'll buy a used and rebuild it before I pay $200 for a new one.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#17 |
What?
I personally had bad luck in rebuilding my wing vents.
Kicked myself for not just nutting up and buying a whole new set.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#18 |
Back in the sticks
Same thing here, dang nut broke off on the bottom of the chrome vent!!! Aaaaaaaahhhhhhhh!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#19 |
![]() Join Date: Aug 2011
#20 |
subscribed
#21 |
![]() Join Date: Feb 2011
Me too....subscibed
MusicMan70 1961 GMC Suburban |
#22 |
I like the rivet tool but there is no link and have searched for hours. please guide me!
#23 |
resurrection
'72 K10 '94 K2500 |
#24 | |
Cluster King
![]() Join Date: Nov 2012
#25 |
2WD Jimmy
![]() Join Date: Mar 2005
This is an old thread. The new repop vent wings are Way nicer. Call Wes at Classic Heartbeat in Wash. state.
