UCA63
Re: CRGRS 66 – Winter Build Thread
yes,The HEI dist. and cap are larger than a points dist.
Unless you're going with a conversion type HEI that fits inside or an aftermarket one altogether. Just a thought before you install trans xm and order driveshafts. It's as easy as using the forward holes in your framerail as opposed to the rear ones. T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
| Bookmarks |
