Closed Thread
Old 10-10-2012, 12:06 AM   #5076
Billett
Billett's Avatar
Re: What did you do to your truck today!
Took a trip to the junkyard and finally got a set of trim rings. Not a perfect fit, but cheap is good
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline
Old 10-10-2012, 01:40 AM   #5077
DangerBoy
Changed the oil and ordered a new hood!
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline
Old 10-10-2012, 03:40 AM   #5078
peglegs
peglegs's Avatar
finishing the brake lines so i can install the engine
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline
Old 10-10-2012, 11:52 AM   #5079
1970 C10 MJW
1970 C10 MJW's Avatar
I just bought a sway bar and rear bumper bracket from brothers truck parts, on sale, shipped them both for $205
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline
Old 10-10-2012, 12:39 PM   #5080
oneoff
oneoff's Avatar
Got the bed assembled and ready for paint, stripped the cab to send to blasting. Sometime in the next few weeks, I'll order up the LS motor. Hopefully, it'll be done by Thanksgiving. Started it around Sept 1st. and rightly named it project "Quickie"
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803
Dennis H
1969 Chevy C10, SWB, LS3,6.2L engine
1969 Chevy Chevelle SS,BBC, Convertible
oneoff is offline
Old 10-10-2012, 01:42 PM   #5081
nlped
nlped's Avatar
^^^Oneoff, looks like that '69 shares some wicked company!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 10-10-2012, 10:16 PM   #5082
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I had a bunch of non-truck chores today. But, I decided to wire this up this afternoon since the "chime"
came in the mail.
In the last few de-bugging test-drives, I realized that my hearing issn't what it used to be. Over the nice rumble,
I just can't hear the click of the turn signal flasher...at least consistently...
So, taking the lead from a Forum Member and other internet wrenches, I rigged this up.
Drilled a little "solder hole" down close to the base of the flasher on each blade. Connected small wires to
bigger wires so I could but blades and connectors in the line to the chime.
I think the chime...about 80db...makes the same sound an elevator door does when it hits "your floor"....
I soldered the connectors on and made the leads longer just in case I want to put in a switch for those times you
have to sit at the light for a long time and your passenger says, "Can't you stop that infernal racket?"
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-10-2012, 10:32 PM   #5083
ole dollor
ole dollor's Avatar
thats something all us old fellows need....
ole dollor is offline
Old 10-10-2012, 10:56 PM   #5084
magwakeenercew2jh
Huh?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-10-2012, 11:37 PM   #5085
Square_78
Square_78's Avatar
Swapped out my door locks today. I was really dreading having to do this. My locks were super worn out and sometimes it would take me 5 min of wiggling the key to get the stupid thing to lock. I bought some replacement GM locks a few weeks ago. Finally today i pulled off my door panels and went at it. Took me 5 seconds to remove the door lock and within 5 min I had the new one reinstalled and working. WOW that was easy! I was expecting to spend half the day working on those things. I also swapped out the ignition as well. That was even easier. Now I can lock and unlock BOTH my doors from the outside! Feels like a new truck! haha
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 10-11-2012, 06:55 PM   #5086
shawno72
C/10 junkie
shawno72's Avatar
Installed my new wheel today What do you think?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 10-11-2012, 06:57 PM   #5087
nlped
nlped's Avatar
Finally got motivated and got rid of the 4 wheel drum brakes and the sky high stance. Still have some work to do, but I'm close on this part. Just have to change out the U-joint to match the '84 12 bolt (Cut off the leaf spring mounts & shock mounts and welded on CPP conversion mounts...why I used it... McGaughy 13" brake kit, Auburn diff, 3.42's, etc) I put under it, and finish up the brake lines to the CPP M/C and P/V.
The "new" stuff...McGaughy 13" front & rear brakes. 18" Boss 338's, 18x8" in front and 18x9.5" out back. Front has 2 1/2" drop spindle, 1" drop coil, 'completely rebuilt '76 upper & lower control arms, and all new MOOG '76 steering pieces/parts. Rear has CPP 4" drop coils and CPP deluxe bent bar (to clear HUGE aluminum diff cover). Exhaust is touching the rearend on the passenger side and holding it up just a tad. I'll fix that tomorrow.
I've got the complete 5.3L/4L60E swap sitting in the garage and I'm waiting on my buddy to free up some time so I can start on the Paint & Body...
Before & After...
Carter
nlped is offline
Old 10-11-2012, 06:59 PM   #5088
rockin562
rockin562's Avatar
That wheel just looks like it belongs there.
rockin562 is offline
Old 10-11-2012, 07:03 PM   #5089
heathbirkendahl
Before & After...
GREAT looking truck!
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 10-11-2012, 08:46 PM   #5090
nlped
nlped's Avatar
Originally Posted by heathbirkendahl View Post
great looking truck!
oooooffffff!!!! S-e-x-y!!!!!
Carter
nlped is offline
Old 10-11-2012, 09:03 PM   #5091
1972SUPERSB
1972SUPERSB's Avatar
Attachment 997338
Attachment 997339
Man that's a nice wheel! Where did you get it?
I painted my steering column and installed ac delco alternator
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline
Old 10-11-2012, 09:07 PM   #5092
ItsRandy
ItsRandy's Avatar
Attachment 997338
Attachment 997339
Very nice.
ItsRandy is offline
Old 10-11-2012, 09:52 PM   #5093
magwakeenercew2jh
That's the right one!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-11-2012, 10:02 PM   #5094
496bb
496bb's Avatar
I like that wheel!
I finally got my intake/carb/dizzy swap buttoned up and got the truck to fire up! (fun for me cause I had never done any of this) figured out i need a new battery, so this weekend will be a new battery and cables. and then maybe I'll get around to installing my new comfort grip style wheel and post pics of it.
496bb is offline
Old 10-11-2012, 10:04 PM   #5095
magwakeenercew2jh
Originally Posted by 496bb View Post
I like that wheel!
Cool.
I'm starting a new thread on today's happenings..."Here's How I Left My Truck".
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-11-2012, 10:45 PM   #5096
ole dollor
ole dollor's Avatar
Originally Posted by magwakeenercew2jh View Post
Huh?
yes that's what i need ....do you have an another one you would sell....
Old 10-11-2012, 11:25 PM   #5097
rockin562
rockin562's Avatar
i got to raise my trans tunnel today.
Old 10-11-2012, 11:54 PM   #5098
heathbirkendahl
Attachment 997338
Attachment 997339
Who makes that wheel? I love it!
Old 10-12-2012, 12:08 AM   #5099
Shyguy
Junior Member
Shyguy's Avatar
We were going to paint the inner fenders, radiator core support, inside the fenders and misc other stuff, but the weather was too cold and damp so we decided to do other stuff.
We installed the hi-torque mini starter, battery cables, distributor cap and wires, tac and heater hoses on the 454 in our latest project, '67 swb stepper.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 10-12-2012, 12:38 AM   #5100
c10boob
c10boob's Avatar
I adjusted the carb, installed a choke cable, changed the thermostat, fixed my oil leak, and ran sea foam through my crank case which resulted in this...
and that picture does no justice, there was a LOT more sludge than shown..
c10boob is offline
Closed Thread
