#6276 |
Re: What did you do to your truck today?
Didn't get much done this weekend.
My 11 year old welded up a couple holes in bed cross members so we can reuse them for the flat bed. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6277 |
I bought a chrome rear bumper that was on craigslist. The guy didn't know if it was original or aftermarket so I made the 60 mile drive and found it was an older Chinese aftermarket bumper but I bought it anyway at a reduced price. I ordered up bumper and license plate brackets from Classic Industries. After modifying 1 bumper bracket and the plate bracket I got the bumper mounted today. It's not running to good right now but it looks a little nicer.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#6278 |
Just a small job but has made a big difference to my interior - and something I've wanted to do for the past two years..
Many thanks to Jeff [62 Longbed] who sent all of the necessary parts to mount my horn button (including the button itself!) across the pond for a great price ![]() ![]()
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
#6279 |
I put in the seats and did some general work on the interior cab... later will put on the newly chromed bumper!
cheers _______________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=538792 |
#6280 |
made some headway on the 66 yesterday. sent my headers out to jet hot, got the engine installed (what a mofo) ordered 2 flowmaster mufflers, radiator temp switch and header bolt kit. today ill install the aluminum radiator, electric fan/shroud, the gm performance serpentine kit and get some plumming done. pictures to follow..
The price of cool aint cheap. |
#6281 |
Finally killed the squeaky clutch pedal. I have squirted here and there and could never get the high pitch squeal to go away. Finally dug under the dash and realized I had bee bitten again by the PO-itis. I disconnected the clutch push rod to lube the pivot bolt. I pulled the rod out and the last 2 inches had a 20 degree bend in it so when you pushed in the pedal the bent angle part of the rod was rubbing really hard against the cup of the master cylinder so it screached going in and out. Straightened the rod, re-installed, presto magico no more screaching!!!! Maybe my wife won't be afraid to ride in the truck with me now.
62 C10, LWB fleetside, 350SBC, Munie 4spd, |
#6282 |
Got the seats all reinstalled. Replaced the bolts on the inside door panel, and put the front bumper back on after having it re-chromed! Sent the front grille to get sandblasted and then painted a matte-black, it was just more affordable than having it de/re-chromed.
russell _________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=538792 |
#6283 |
made some progress today, engine in, serpentine belt kit installed. ran into some snags so didnt get as much done as wanted.... more tomorrow.
#6284 |
Got my panels back from the powder coater. Rebuilt the regulators, put sound deadoner in the doors, adjusted the plate so the doors close smooth, new arm rests, new felts and rubber. I wish I would have picked up some new screws and handles. Back to classic parts.
66 shorty ![]() |
#6285 |
Senior Enthusiast
Got the stainless trimmed windshield back in place after what seems like a month of prep. Thankfully it was very uneventful.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6286 |
![]() Join Date: Nov 2008
Thanks for the kind words Barney (UK62LW) the interior is looking good my friend !!!!! Glad I could Help you out ....
#6287 |
Redneck Hillbilly
Parked it. Once I can get a couple other projects out of the way she's going in the shop, I'm through with that inline 6. Sure it is a cool old engine, but the cool factor doesn't make up for the poor drivability and even worse fuel economy. Soon to be for sale: Chevy 292 with new HEI distributor, rebuilt carb, and SM420 4-speed transmission......
#6288 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#6289 |
Got the front leaf spring hangers off today so I can start fabbing up new ones!! Yay for progress!
Posted via Mobile Device |
#6290 |
Senior Enthusiast
Finished putting all the parts back on the truck, returning it to service. I always miss driving it when it’s torn apart, so I try to keep it those periods as short as possible.
![]() I’m also looking for input on whether adding the chrome locking strip around the rear window would be an improvement, and does anyone know how long they hold up or if there are any problems with the chrome version?
#6291 |
Got the front swaybar mounted after the 84 front suspension swap.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#6292 |
over the last two days ordered porterbuilt rear bag kit, CPP sway bars, CPP disc brake kit with 2.5" spindles, 2" springs and matching shocks. Need to get some tear down happening!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#6293 |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#6294 |
Heres a pic of the back window w/the chrome lockstrip
#6295 |
Liking the look. Do they make it for the big back window? LMC?
------ 65 Chevy C10 Fleetside |
#6296 |
Found it on LMC. 15 bucks for the BBW.
#6297 |
Installed a cd player and speakers!
#6298 |
please post pictures as i am planning on doing it as well and i need ideas.
1970 442 convertible 1970 Cutlass SX 1962 Chevy Stepside 2011 GMC 3500HD Crewcab SLT DRW |
#6299 |
are you asking about the windo install, or the CD speaker install...
#6300 |
Rear tank install is done, will run lines to canister filter under cab today, filler wi;; be in bed far left corner for now, later install side panel filler door.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
