Old 08-20-2012, 03:58 PM   #26
dieseldude4bt
Re: 61 GMC 4x4 1ton build
Very nice, it will look factory.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 08-20-2012, 05:30 PM   #27
rambler
MOVE OVER
rambler's Avatar
nice work.. I am always envious that some people have this type of craftsmanship, I can turn a wrench and bolt on stuff, better than some.. but this looks like real talent..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 08-20-2012, 10:13 PM   #28
ky-donzi
Thanks guys, I do have to admit I have access to a plasma cnc, and I'm pretty decent at autocad... So that explains the nice cuts
ky-donzi is offline   Reply With Quote
Old 08-20-2012, 10:49 PM   #29
Jeff La
Man You are one LUCKY GUY, that's what I dream about
Jeff La is offline   Reply With Quote
Old 10-10-2012, 01:21 PM   #30
dieseldude4bt
Any updates on this project?
I need a photo fix!!!
Old 10-10-2012, 10:21 PM   #31
ky-donzi
Actually took some pics today, got the body mounts complete, a/c mount built, engine degreasers and painted, And engine crossmember made, still got some work to do on the front crossmember ahead of the engine...... put some some new lift springs on the front today,,,,, sets a little high for my liking... Hope when I drop the 900lb engine in it will settle some..... Post pics later....
Reid
Old 10-10-2012, 10:56 PM   #32
ky-donzi
here are the pics
Old 10-11-2012, 11:28 AM   #33
piratexpress1369a
piratexpress1369a's Avatar
looking good so far
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-11-2012, 01:18 PM   #34
dieseldude4bt
How much room between the crossmember and the front axle? Photo makes it look close
Old 10-11-2012, 04:45 PM   #35
ky-donzi
I'd say approx 4-5 inches before the engine is in it.... Going to try to reinstall the engine this weekend .... Getting close to having all the fab work done I think
Old 11-14-2012, 12:32 AM   #36
dieseldude4bt
Updates?
Old 11-14-2012, 09:30 AM   #37
ky-donzi
Nothing exciting.
I have re-gasketed the 4BT, and done all the normal checks (KDP, torque rod bolts, inspect other bolts, ect) I have re-gasketed the SM465 and NP205 checking each for wear and damage. I bought a HOTZY steam pressure washer to clean parts and found that the mount between the trans/tranfer case was broke about 3/4 around the perimeter, so replaced that. I have got the 2XT (ranger) re-gasketed and finally got the shift motor to work properly.
It has been slow work, but I really want everything close to right before I reasemble it. Im not going to have the final product quality of "things" over on 4BTswaps but I dont wanta just throw it togather either.
I perdict that i should have it runing but not driving during the Christmas season.
Old 12-02-2012, 11:57 AM   #38
ky-donzi
Progress! I will post pics later, got the frame POR15'ed, all the brake/fuel lines ran, fab up a front crossmember (the one under the radiator) mounted my sway bar. Plan on dropping the engine in for the final time, and bolting down the cab for good this week. Still got hours and hours to go, but at least now I get multiple items accomplished every time I work on it.
Old 12-02-2012, 12:27 PM   #39
dieseldude4bt
Good to hear progress look forward to the pics.
Sometimes you wonder if it will ever come together, just keep at it were pulling for you.
Old 12-03-2012, 10:53 PM   #40
ky-donzi
Name:  61 gmc 12-2-12 006.jpg
Name:  61 gmc 12-2-12 004.jpg
Name:  61 gmc 12-2-12 018.jpg
Name:  61 gmc 12-2-12 023.jpg
Size:  55.7 KBhere are the photos
Old 12-03-2012, 10:54 PM   #41
ky-donzi
few more
Old 12-10-2012, 11:52 PM   #42
ky-donzi
More progress.... Engine is in... Trans and transfer case CHECK.....Ranger OD...CHECK.....Cab bolted down.... CHECK.....might get to start the 4bt this weekend!!!
Old 12-11-2012, 12:21 AM   #43
rs74
rs74's Avatar
What did you have to do to bolt that cab and doghouse up to the newer frame? In one picture it looks like the doghouse sets up above the frame quite a bit like maybe there is a body lift on it. Where you able to take the 61 cab mounts and just fab them onto the newer frame?
rs74 is offline   Reply With Quote
Old 12-11-2012, 12:28 AM   #44
ky-donzi
few more
I used a suburban frame which is much flatter when compaired to a 73-87 pickup frame.
Then I torched all the suburban mounts off the frame and searched on line, found some diamenions and fabed up new frame to cab mounts.
The cab actually sits about 1-1/2 above the frame contour... That would be close to factory I would think.
If it were a 2wd it would sit maybe a 1" higher than its suppose to
Old 12-11-2012, 01:44 AM   #45
rs74
rs74's Avatar
Thanks. I was curious because I have an 84 K30 frame and running gear that I have that about putting an older body on or taking the running gear out of the K30 and putting it into an older truck. Not sure if one would be easier over the other. Thanks
Old 12-11-2012, 09:35 AM   #46
ky-donzi
Well IMO you have a couple opitions. First I wouldnt use the K30 frame unless it was a last resort. You didnt specify the year so I am going to assume you are talking about 60-66
I would either
get a old model 4x4 frame and use your running gear. This would be the easiest. As the cab would already be a bolt on deal, and the F/R axles wouldnt be hard to modify.
OR, if there are no 4x4 frames to be found like in my case.
Get a suburban frame and mount your cab and running gear to it like I did.
the frames on the 73-87 trucks swoop down real low under the cab and would be hard to mount too. The 73-87 suburban frames are nearly flat and have almost the same wheelbase. I believe it is 129.5 instead of 131. So proabaly wouldnt be noticible.
I had never considered a cab/chassis frame and they might have been made different.
I am installing a flatbed so wheelbase is not as important to me.
I am no expert, but these are my findings.
Thanks and good luck
Old 12-11-2012, 09:38 AM   #47
ky-donzi
Here is the truck awaiting the rest of the hose connections and brake lines. Nice to get it on the lift. I can tell you this it about killed me and another guy getting it on there.... with no power we rolled it up the ramps... makes you really respect horsepower.... that 6" ramp that we had to roll up liked to killed us
Old 12-11-2012, 01:43 PM   #48
ky-donzi
[QUOTE=ky-donzi;5752096]Well IMO you have a couple opitions. First I wouldnt use the K30 frame unless it was a last resort. You didnt specify the year so I am going to assume you are talking about 60-66
I would either
Thanks and good
I should clarify a few things I said
You didn't specify what cab but I assume you mean 60-66
And.
Use a old model frame (I.E.) one that matches your cab and swap axles from your k30
Old 12-11-2012, 04:38 PM   #49
rs74
rs74's Avatar
[quote=ky-donzi;5752561]
I would either
Thanks and good
And.
Yeah I guess I should have been more specific. I was refering to putting a 60-66 cab on the 84 K30 C&C frame. The 84 frame does swell up at the rear axle. It might just be easier to find a 60-66 C30 truck and put my running gear in.
Old 12-17-2012, 11:06 PM   #50
ky-donzi
RUNNING!!!!!!!!!!!!
