Old 10-15-2003, 03:31 PM   #1
smokekiki
Mike
smokekiki's Avatar
Oil pressure gauge
My oil pressure gauge pegs,and stays there as soon as the truck starts.What could be the problem?Sending unit?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 10-15-2003, 03:44 PM   #2
A.P.
Black 72 Chevy
A.P.'s Avatar
When did this issue started happen?
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 10-15-2003, 06:17 PM   #3
smokekiki
Mike
smokekiki's Avatar
Just bought the truck.The prev owner said it has always been that way.He had it ten years.
Old 10-15-2003, 06:24 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I have a factory mechanical oil pres. gauge. Mine does the same thing, but I don't worry about it.
When your engine is cold, oil thickens, and as your engine warms up it gets a little thinner. My gauge will peg for about 15-30min till the engine warms up, then my gauge will read about 2/3 pressure (I think my factory gauge is a 40psi, they say on the front of them when you take your cluster apart: either a 40 or a 60psi)
Don't worry about it unless you don't have oil pressure! You can't have too much...
If your gauge is electrical, then I would check the sending unit, or the gauge, it should read 0 when you turn the key on.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 10-15-2003, 06:29 PM   #5
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Sounds just like mine. Only mine sticks sometimes - can do it anywhere. Also, when mine is warm it runs dangerously close to 0 at idle. And that's with 20W50!
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-15-2003, 06:39 PM   #6
A.P.
Black 72 Chevy
A.P.'s Avatar
When I first turn my truck on, the oil pressure goes above the middle mark but it never pegs at the high mark. I'm also running 10-40 oil.
Old 10-15-2003, 09:03 PM   #7
Gordo
Smile
Hey smokekiki, what's up? My answer to your question is that you have a sending unit installed meant for an idiot light. Replace it with a gauge type sending unit.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 10-15-2003, 09:10 PM   #8
smokekiki
Mike
smokekiki's Avatar
Hey Gordo,how You doing?I just bought this suburban.Haven't got to play with it yet.It is a '71 with a factory BB.It was mounted on a '69 4X4 frame.Was 1/2ton,now 3/4ton.I,ll try to post some pics tommorrow.
Old 10-15-2003, 11:59 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is no sending unit on this if we are talking aboutt eh stock set up, all there is is a tube from the engine to the guage.
Pegging out just means you have some damn good oil pressure, and possably, the wrong oil.
You don't run 80/90 gear oil like Jason does do you?
Old 10-16-2003, 07:54 AM   #10
smokekiki
Mike
smokekiki's Avatar
Thanks Longhorn Man,sometimes it takes a smack on the head to jump start my brain.The line is connected to the block right above the oil filter.Is this the proper place for a big block?It has 20-50 oil.
Old 10-16-2003, 08:34 AM   #11
tom hand
CCRider
tom hand's Avatar
Bone stock motors put out 40-50 psi max and that's what the guage is designed for. More than likely the motor has been rebuilt with a higher pressure oil pump so it pegs the guage. I don't think it hurts the guage...I ran a motor in mine that keep the guage pegged all the time for two years, then switched to a GM crate motor and the guage works fine.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-16-2003, 08:02 PM   #12
Gordo
My mistake, I was thinking electric gauges. My truck progress is slow. Seems like everything else comes first. I hope to rehang the cab on the rotiserie and finish up welding the head liner back in this Fall but, (there is always a but) I have a few other projects to finish first. Lets see those pics!
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1951 Wife
Old 10-16-2003, 08:07 PM   #13
StingRay
StingRay's Avatar
The stock gauge is a 60 psi unit and with my high volume pump it was always pegged when cold. I swapped in an 80 psi unit often found in the big truck gauge clusters but are overlooked as it is usually the tachs and vacs everybody is looking at them for. Works great.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
