Re: 69 c20 rear suspension swap
Thanks. I already found through google searching, that the rear from 88 and up will be too wide. I dont think I really need to worry about the strength of 10 vs 12 bolt, as I wont use the truck for hauling, nor will it have a big motor. I was wondering though, and just posted the question if perhaps a second gen Camaro rear would swap into the truck. I know it's narrower, and that may be what I want so I could fit wider tires and rims inside the wheel wells. Even if I had to widen the wheel wells inside the bed an inch or two
