Closed Thread
Old 10-12-2012, 04:16 PM   #6301
CRGRS 66
CRGRS 66's Avatar
Re: What did you do to your truck today?
Originally Posted by Rich 5150 69 View Post
Rear tank install is done, will run lines to canister filter under cab today, filler wi;; be in bed far left corner for now, later install side panel filler door.
Outstanding work on the tank install, looks like the factory would have done it Rich!!!!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 10-12-2012, 04:18 PM   #6302
mark 66
took the cab to the media blaster.welded the outer and inner pass door skins on
mark 66 is offline
Old 10-12-2012, 04:22 PM   #6303
CRGRS 66
CRGRS 66's Avatar
Ordered a power steering box, pump and pump brackets from Marshall Auto Wreckers in Alberta, $90.00 seemed like a killer deal to me. Probably cost another 20-30 to ship it
Craigerrr
CRGRS 66 is offline
Old 10-12-2012, 06:33 PM   #6304
Rich 5150 69
Rich 5150 69's Avatar
Thanks for comp..Craig, that the look I was after...more mods to come later.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 10-12-2012, 07:44 PM   #6305
Hx16457
Hx16457's Avatar
Cleaned around it, because I get the first new set of tires, since the build began 3yrs ago, in the morning.
I am excited to get some real rubber on her ("Sally"), my wife named her Sally. She said any thing you spend so much time on must have a name, and it must be a girl to keep my full attention as she has.
Anyway I am going to put new lugs on her in the morning so her new shoes will stay put.
I also removed the tape that was holding the door seals in place while the glue dried.
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 10-13-2012, 12:26 PM   #6306
russellmalcolm
russellmalcolm's Avatar
I took the grinder to the front grille, put the GMC letters on, put the headlights together, put the grille on the truck, took off the mirrors and cleaned them and repainted them... not a bad day!
You can see pics at my build page: http://67-72chevytrucks.com/vboard/s...=1#post5644784
russellmalcolm is offline
Old 10-13-2012, 01:49 PM   #6307
Improbcat
Improbcat's Avatar
Converted from worn, jamming coloumn shift to a Mr Gasket floor shifter. Went pretty well and took about 3 hours.
Anyone want the old column shift linkage? free for the cost of shipping.
Improbcat is offline
Old 10-13-2012, 01:56 PM   #6308
CRGRS 66
CRGRS 66's Avatar
I am not inrterested in the linkage, but I am wanting to find out how to remove it. I am rebuilding a column, and struggling with the last bit of tear down. The tab between the two linkage arms, is it press fit? welded?
Craigerrr
CRGRS 66 is offline
Old 10-13-2012, 04:05 PM   #6309
Improbcat
Improbcat's Avatar
Can't help you, sorry' I just unbolted the linkages where they attach to the arms on the column and left the arms in place.
Old 10-13-2012, 08:02 PM   #6310
Bradydz
Bradydz's Avatar
Where did you get the tank?
Bradydz is offline
Old 10-13-2012, 09:28 PM   #6311
Hx16457
Hx16457's Avatar
Put new shoes on Sally;
Hx16457 is offline
Old 10-13-2012, 10:24 PM   #6312
johnny mac
I installed an interior light with door jamb switches.
Interior light when I got the truck:
Door jamb switches:
Installed:
Now I can see:
johnny mac is offline
Old 10-13-2012, 11:41 PM   #6313
dantimdad
dantimdad's Avatar
Well done on the dome light!
That's my plan as well.
BTW, did you tap the holes in the door posts?
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 10-13-2012, 11:58 PM   #6314
Rich 5150 69
http://www.bobdrake.com/ItemForm.asp...b-9f358301a978
Old 10-14-2012, 11:55 AM   #6315
johnny mac
Steven
I didn't tap the holes. The pins come with a small nut. I drilled a hole slightly larger than the pin threads and then used a washer and tightened it down with the nut.
John
Old 10-14-2012, 12:30 PM   #6316
b.eddy's72
b.eddy's72's Avatar
Just scored both uncut non-rusted inner fender wells and both door glasses for the 66 for $80 from a guy I found on Craigslist. Super nice guy with a really clean 65 that he almost has complete. Turned him onto the forum hopefully he will join.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline
Old 10-14-2012, 02:23 PM   #6317
jsdoyle
jsdoyle's Avatar
John
Nice job. On my list of things to do as well.
65 Chevy C10 Fleetside
jsdoyle is offline
Old 10-14-2012, 07:35 PM   #6318
markeb01
Senior Enthusiast
markeb01's Avatar
Fyi – here’s an article on the installation some might find helpful. I followed this when installing my door switches:
http://www.persh.org/pickup/DomeLight.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 10-14-2012, 08:12 PM   #6319
johnny mac
yep, that is the article I referenced when doing mine. Very helpful.
Old 10-14-2012, 09:54 PM   #6320
Chevy Fleetside
Chevy Fleetside's Avatar
Here is a good one for you.
A few weeks ago (ok about 4) I had my truck hooked up to start it. It wouldn't start and I had no spark to the plugs. A friend of mine came down today with his volt meter and we started with the switch and had 12 volts there. Then out to the coil (HEI ignition) and no volts there. I pushed the plug back on the switch and 12 volts popped up. I tried cranking but no spark, the 12 volts went away. My new wiring harness has a fuse for the coil and it blew. Why did it blow.. Who knows..
Took the cap off to make sure the rotor was in there and even turning and it was. Want to make sure the dodad was in the middle of the cap touching the rotor and it was. Finally I pulled the coil to see if make I broke a wire. I never took the coil out of the dist (which is a brand new Mallory) and as soon as I lifted it up we saw that the coil was in upside down. Who ever put the coil in at the factory put it in upside down. I flipped it over sprayed the carb with starting fluid and my truck made that BBC sound through open headers. What a smile I had on my face and then after that I had another friend come down adn help me put the hood back on.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 10-14-2012, 10:32 PM   #6321
CRGRS 66
CRGRS 66's Avatar
very nice... it is the little things isn't it?
Craigerrr
CRGRS 66 is offline
Old 10-14-2012, 10:58 PM   #6322
Blainethemono
Blainethemono's Avatar
Barely got home from the dump, when I realized my truck was running off of battery.....
Voltmeter was dead meat....... Seems I may have an older alternator wired into an earlier external voltage regulator that may be prone to failures...... running a 76 SB 350... and I sure would like to convert to an internal VR.
Blainethemono is offline
Old 10-14-2012, 11:34 PM   #6323
Rich 5150 69
Here, we just beat this to death ....http://67-72chevytrucks.com/vboard/s...d.php?t=546271
Old 10-15-2012, 01:47 AM   #6324
russellmalcolm
I actually did not do this myself, but I got the wiring done for the headlights and turn signals at a small auto electric shop in mussafah, all working now! Still need some work on the fuel gauge, wipers, and new CD player, and will get to that shortly.
My Truck Build:
http://67-72chevytrucks.com/vboard/s...=1#post5647667
Old 10-15-2012, 06:57 AM   #6325
killerb68
axle flip on my '66 GMC
killerb68 is offline
Closed Thread
