10-14-2012, 05:43 PM | #1 |
86 High Sierra
Here is my farm find. got it for $1000. Her daughter wrecked it and they were told the frame was bent, So they parked it and it sat for about five years.
10-14-2012, 05:56 PM | #2 |
Re: 86 High Sierra
the engine is in need of some serious help. It hardly runs doesn't downshift properly has no response. so time to freshen the 305 up. I know the 305 the world best boat anchor I've heard them all. but whatever i use will bolt on to a 350 when the time comes. trans fluid has some miles on it but not burnt and the transfer case works fine.
10-14-2012, 06:02 PM | #3 |
Re: 86 High Sierra
Here are some tear down pics.
10-14-2012, 06:03 PM | #4 |
Re: 86 High Sierra
Q-jet gone!
10-14-2012, 06:07 PM | #5 |
Re: 86 High Sierra
look at the surprise I found under the intake! Years of neglect. That is a load of carbon. sorry about the image quality.
10-14-2012, 06:12 PM | #6 |
Re: 86 High Sierra
All cleaned up and ready for assembly.
10-14-2012, 07:17 PM | #7 |
Re: 86 High Sierra
Wow, I am sure your performance will be greatly improved after this clean up... Good work.
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
10-14-2012, 08:34 PM | #8 |
Re: 86 High Sierra
Now things are looking better
Posted via Mobile Device |
10-14-2012, 08:37 PM | #9 |
Re: 86 High Sierra
All buttoned up! Found a coolant leak
10-14-2012, 08:41 PM | #10 |
Re: 86 High Sierra
Running much stronger. Still need to do some carb adjusting.
10-14-2012, 08:45 PM | #11 |
Re: 86 High Sierra
Your doing a great job, already looks 110% better!
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
10-14-2012, 08:46 PM | #12 |
Re: 86 High Sierra
Couldn't reuse the valve covers so decided on some cheap chrome ones. It's amazing what sitting will do
10-14-2012, 08:51 PM | #13 |
Re: 86 High Sierra
Figured out the coolant leak. I didn't lube the o ring under the water neck. And upon closer inspection I put the fuel filter on backwards.
10-14-2012, 09:32 PM | #14 |
Re: 86 High Sierra
Nice man... Good to see another High Sierra not too far away
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
