Old 10-15-2012, 05:43 PM   #1
scotteric
finally working on my 68
wanted to give everybody an update on the 68 chevy im working on
so far i have removed the "in cab" gas tank and replaced it with a 16 gallon fuel cell ///////i also have a "flush mount" cap that i am going to route up through one of the stake pockets on the bed.....
new (to me) 8' bed ready to go on
lowered 4" in the back along with new shocks, shock relocators and an adjustable panhard bar.....
will lower the front after I get the bed back on and see how it sits......probably 2-3 inches tho
starting bodywork
replacing cab corners and inner and outer rockers on both sides as well as fixing some pretty serious floor rust
the passenger side is all screwed together aligned etc///ready to weld but havent touched the drivers side yet
i bought a nice set of re-habbed doors so they will be going on as well
new front fenders (after I reload my wallet a little)
heres how the truck looked when i bought it
scotteric is offline   Reply With Quote
Old 10-15-2012, 05:56 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: finally working on my 68
Looks like you are doing a great job. Have you tried to set the bed down on the truck since you installed the tank? I am working on a truck with a simeler tank and am having clearance issures for the fuel lines on top of the tank. I know your fuel lines are down below, but your filler neck is not. It looks to be even taller than the filler lines are on the truck I am working on. Of coarse the truck I am working on has a wood floor. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-15-2012, 06:30 PM   #3
scotteric
Hi Wes....I haven't tried to fit the bed yet but am sure I'll have room....
According to my measurements the bed support rails are 3" high ( i have a steel floor )and the very top of my fill tube where it goes across the tank is 2.5".....of course I'll have to notch 2 of the supports for the fill but that isn't a real big deal....I'll probably throw a little "bridge" across the gap tho
I'm coming out wit the rubber elbow as shown then aluminum tubing to the corner of the bed where I'll have another elbow with more tubing ran up inside the stake pocket to my flush mount fill
Old 10-15-2012, 07:22 PM   #4
Classic Heartbeat
Sounds good. It must be a wood bed issue with the one that I am doing. I have the same fuel feed and return lines as you do, only they are on top of the tank. They actualy touch the bottom of the bed. So I am going to be changing them out. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-02-2012, 09:10 AM   #5
scotteric
truck is getting there.....
inner and outer rockers ,floors, other bodywork, all done...
filled old gas tank fill
shaved driprails
as soon as i get done sanding offf the NINE! layers of paint on the rest of the front end im ready to spray primer
