![]() Join Date: Nov 2007
Re: new lt1 where do i start?
X2 on 6772 comment.
Must keep TPS IAC VSS ECT left n right 02's knock sensor map IAT whatever it uses to know what position the engine is in(crank, cam, or both) leave the coil obviously delete rear o2's and burned from pcm oil level anti theft and have it burned from pcm oil pressure you could likely delete and use the original setup for the truck
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
