Old 10-16-2012, 12:07 AM   #1
blazins10
blazins10's Avatar
700r4 mounting question
So I installed a 502/700r4 in my 63 shortie shop truck and I had a tube trans crossmember from a different project so I bolted up everything so my question is I leveled the motor/trans combo off the carb mounting flange but end of trans seems high but everything clears is that right ?
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 10-16-2012, 07:04 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 700r4 mounting question
You'll just have to pay attention to the pinion angle of your rearend...which you would need to do anyway with a drivetrain swap.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-17-2012, 12:17 AM   #3
Captainfab
60-66 Nut
The trans output shaft and the pinion need to be on the same plane. Otherwise you can have driveshaft vibration issues.
Old 10-17-2012, 01:00 AM   #4
blazins10
blazins10's Avatar
i understand about pinion angles , which is not what i was asking about
its in relation to mounting the trans crossmember , im not using a bolt in one cause i stock floored my frame
Old 10-17-2012, 11:08 AM   #5
vin63
vin63's Avatar
If you've already made your calculations for crank centerline height, leveled your engine/trans where you want it, and mounted the drivetrain, then what is your question? What is a "stock floored my frame"? This is a simplified diagram/explanation of what I generally use for calculating pinion angles - http://markwilliams.com/driveshafttech.aspx. As Captainfab mentioned and what I noted in my earlier post, you'll need to confirm pinion angle according to where your driveline components end up being mounted to ensure proper drive shaft operation. I build and set up a lot of drag car chassis and due to really tall rear tires, very rarely are the engine/trans and the rearend housing are at the same height.
Old 10-17-2012, 06:46 PM   #6
luvbowties
luvbowties's Avatar
Question Re: 700r4 mounting question
The end of the trans is not "noticeably" above horizontal, is it?
luvbowties is offline   Reply With Quote
