Closed Thread
Old 10-17-2012, 03:48 PM   #5151
c10srule
c10srule's Avatar
Re: What did you do to your truck today!
fixed my guide plate and gave my tires a beating
c10srule is offline
Old 10-17-2012, 03:50 PM   #5152
Mister-B
Replaced my battery, as well as the cables and terminals. Put in a new air filter and top.
Mister-B is offline
Old 10-17-2012, 06:49 PM   #5153
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
I pulled mine out of the garage so a guy could take pictures of it. He is building our mantel in the living room for us and want to show his dad my truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 10-17-2012, 07:35 PM   #5154
mcmlxix
Collector of Projects
mcmlxix's Avatar
went to the pick-a-part yard... they only had one 71 LWB that was beat up and stripped... I did go by the S10s and pull some 175 amp main fuse blocks to eliminate the old fusbale link... I stole this idea from Whitels1 who did an LS swap on his square body K5 blazer ...
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 10-17-2012, 09:44 PM   #5155
shopking72
shopking72's Avatar
Drove it. Enjoying the fall weather before it goes into winter hibernation.
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 10-17-2012, 10:12 PM   #5156
69GWC
That truck is very clean looking, very nice ride you have.
69GWC is offline
Old 10-17-2012, 11:18 PM   #5157
shopking72
shopking72's Avatar
Thanks 69GWC!
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 10-18-2012, 12:19 AM   #5158
Shyguy
Junior Member
Shyguy's Avatar
My son installed the Holley carb (1850) on the 454 in my '67 swb stepper and hooked up the linkage and fuel line. While I filled the radiator with anti-freeze.
We pushed the truck out of the garage and started the engine for the first time after putting it in the truck using a temporary gas tank.
The mini starter I got from DB electric worked great without any shimming.
The truck fired up after the fuel pump built up pressure.
We ran the truck for a while until the thermostat opened and topped off the radiator.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 10-18-2012, 12:56 AM   #5159
ghostvbhc
ghostvbhc's Avatar
I finally got both of my brake lights working with the lights on, replaced the one rocker arm that kept popping off the push rod, and over the weekend ended up getting the power steering put in and it drives like a charm now, finished painting it, and put side mirrors on that I picked up from o'reillys.
Edit: ill have to upload the pictures tomorrow, they're too big to upload from my phone.
1969 Chevy C10 250 straight six. Still a work in progress.
ghostvbhc is offline
Old 10-21-2012, 01:08 AM   #5160
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Just to prove to myself that I'll never be *done*, I decided to put in the new
M & H under dash wiring harness. So, in the course of doing that (and still trying to figure out why ALL of my gas gages don'e seem to want to play fair with the new sending unit), I broke the bezel.
So, I bought a new one from a Seller on the Forum and filled it up again. Gotta go out and crawl around under the dash tomorrow, I guess. But I feel lazy.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-21-2012, 01:32 AM   #5161
VWNate1
VWNate1's Avatar
Question Re: What did you do to your truck today!
What Tachometer is that ? .
So far no joy finding a 6 cylinder factory tach , one like yours will do , I just need to know brand etc. so I can go dig one up .
TIA ,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-21-2012, 01:37 AM   #5162
hayhauler71
hayhauler71's Avatar
Got my cooling fan brackets made and got them mounted to the radiator
Fuzzy
hayhauler71 is offline
Old 10-21-2012, 02:02 AM   #5163
magwakeenercew2jh
TIA ,
It's an Autometer.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-21-2012, 08:57 AM   #5164
VWNate1
VWNate1's Avatar
Thumbs up Re : Auotmeter Tachometer
Originally Posted by magwakeenercew2jh View Post
It's an Autometer.
THANX ! this means Kragen has it IIRC ......
-Nate
Geezer
VWNate1 is offline
Old 10-21-2012, 11:11 AM   #5165
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today!
Drove mine 2 1/2 hrs one way to a car show in NC yesterday.
Andy4639 is offline
Old 10-21-2012, 11:30 AM   #5166
magwakeenercew2jh
Re: Re : Auotmeter Tachometer
Yeah. O'Reiley's up here in the North....But you better call 'em first. They have a display
of the tachs. But, up here, the local store seems to have to order everything.
It's a 3 3/8" face. I think a model 5795, 6809, or 6811...but not sure.
I just checked....There are 240 tachs on E-Slay just in case a Forum Seller
doesn't one for ya.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 10-21-2012, 05:53 PM   #5167
Shyguy
Junior Member
Shyguy's Avatar
I sanded the dents and around them on my '67 cab and C10srule put bondo on dents that could not be popped out.
The repairs looks great.
Next weekend we will finish sanding the cab and front clip.
It is nice to have the truck running again so we don't have to push it in and out of the garage.
Shyguy is offline
Old 10-22-2012, 04:19 PM   #5168
ghostvbhc
ghostvbhc's Avatar
Finished painting it and put the side mirrors on, the headlights are out because we have to replace them.
We had to notch out a small piece of the fender well to have the lines clear for the power steering gearbox.
We got the power steering pump mounted in with a few of our custom brackets that we had to make, but it definitely works extremely well. We might have to get another radiator hose because it looks like it's slightly touching the belt. And, I put a chrome oil breather on, a new air filter, and fuel filter.
This is the ground wire that kept giving me my brake light problems and all I had to do was clean it and replace the screw and every light works now.
Old 10-22-2012, 05:32 PM   #5169
VWNate1
VWNate1's Avatar
Thumbs up Re : 6 Cylinder Tachometer
doesn't one for ya.
So far , no joy on a stock one =8-( .
Sunday I was doing my Physical Therapy in Pick-A-Part and stumbled across a cherry 1978 Jaguar XJ6 , I scored the tach for $13 and will see if I can adapt it to suit ~
I don't want a flashy guge , I want a stock looking one .
-Nate
Geezer
VWNate1 is offline
Old 10-22-2012, 05:36 PM   #5170
VWNate1
VWNate1's Avatar
Post Re : Power Steering Hoses
That radiator hose is too short . not to mention the crappo accordion typ .
Those P.S. hoses are wrong too , the corect ones are bent differently and clear the inner fenderwell easily .
All these parts are available cheaply @ Rock Auto.com
-Nate
VWNate1 is offline
Old 10-22-2012, 06:04 PM   #5171
The Big Green
Pulled my leader hose because Im dumb and trashed it lol. This is what I did the other day! Happy Halloween!! Since the cops got called and tried to make me do away with my Halloween I said F it and didnt. I did put yellow tape around it like a crime scene.
The Big Green is offline
Old 10-22-2012, 06:11 PM   #5172
69GWC
Filled it up with $3.19 a gallon gas... lol
69GWC is offline
Old 10-22-2012, 06:36 PM   #5173
HotRod C/10
HotRod C/10's Avatar
painted my frame.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 10-22-2012, 07:08 PM   #5174
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today!
I sanded and stripped paint off my 67 SS steering wheel.
Andy4639 is offline
Old 10-22-2012, 07:25 PM   #5175
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by HotRod C/10 View Post
painted my frame.
Did you paint it with the front crossmenber on or off? Curious cause I need to do mine.
VDOG is offline
Closed Thread
