Old 10-18-2012, 05:56 AM   #1
melhilburn
melhilburn's Avatar
Valve cover and side panel gaskets 292
Best place to find valve cover and side panel gaskets - Also do I have to remove the distributor to install the front side panel gasket?
melhilburn is offline   Reply With Quote
Old 10-18-2012, 08:02 AM   #2
1963c-10
1963c-10's Avatar
Re: Valve cover and side panel gaskets 292
I get my gaskets fom NAPA or O'Reilys here. We also have advanced Auto and Western Auto. The front cover will come off....it'll be tight, but I did my 230 side covers w/o removing the dist.
1964 Short bed trailer
Old 10-18-2012, 11:07 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
If you're local parts house does not carry them, you can still order them online at Summit Racing. And, yes, for the 292, you'll need to remove the distributor to unbolt an remove the forward side/push rod cover.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
