Old 10-18-2012, 01:05 AM   #1
melhilburn
melhilburn's Avatar
Install new transmission
Is it very difficult to change out transmissions or should I have someone do it - Obviously I would rathere do it myself that's half the fun - saving the money is the other half
melhilburn is offline   Reply With Quote
Old 10-18-2012, 07:48 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Install new transmission
we can walk you thru it, what is it that you are running and wanting to change over to?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-18-2012, 03:34 PM   #3
melhilburn
melhilburn's Avatar
Im pretty sure I'm running a 64 saginaw 3 speed manual - found what looks like a nice rebuilt unit on ebay for $400.oo
Old 10-18-2012, 04:08 PM   #4
1963c-10
1963c-10's Avatar
Not a very hard job. Disconnect driveshaft, some clutch linkage, unbolt from bellhousing...enough of us here to help out. Might as well throw in a new clutch if you are replacing the trans...just my two cents worth.
1964 Short bed trailer
Old 10-18-2012, 05:00 PM   #5
Wrenchbender Ret
If you go back with the same trans. It is about as easy a job as you can get for replaceing a trans. Like C-10 says, drop the drive shaft, disconnect the shift rods. Remove the lower flywheel cover. The 2 lower mounting bolts come in from the inside. Remove the upper bolts & if you are fairly stout get under it & slide it out. I used too pull them that way but I'm old & weak so I have to use a jack. You dont need to undo any clutch linkage. You can look up into the house ing & see if the clutch disc is wore out. It should have grooves on both sides. If the linings look good & it works good ther is no need to replace it. Spin the brg. on the TO brg. If it makes any noise it needs replaceing.
Wrenchbender Ret is offline   Reply With Quote
Old 10-19-2012, 06:09 AM   #6
melhilburn
melhilburn's Avatar
Ok I'm going for it - I'm sure I will have more questions - but you guys sure have all the answers - I live in the DC suburbs so getting parts is a pain - I should probably buy the clutch parts and do the whole job once and get it over with - So it may be a week or two before I tackle this job - I'll be back
Old 10-19-2012, 07:00 AM   #7
C-10cutty
C-10cutty's Avatar
My son and I just pulled the one out of our c-10. It really helps to remove the tranny hump and work from above. He lifted it out from up top and the t-5 will go in that way.
C-10cutty is offline   Reply With Quote
Old 10-19-2012, 08:22 AM   #8
1963c-10
1963c-10's Avatar
Very true....does help w/access. Good tip
