11-30-2011, 10:25 PM | #76 |
Re: Inline 250 - T3 Turbo - w/ Video
The T5 in our S10 has started making alot of noise in the first three gears. The first three gears have seen alot of abuse though.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-13-2012, 08:54 PM | #77 |
How's your fuel economy so far with this? I get my block and head back soon and am curious what to expect.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
02-13-2012, 09:46 PM | #78 |
wow that looks like it really wasnt that hard to do. what did you use for engine internals like camshaft and such.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-13-2012, 10:59 PM | #79 |
I actually just got my speedo / odometer back working with the 5 speed. I will a have to calculate it. I have always wondered also.
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
02-13-2012, 11:03 PM | #80 | |
I used the stock head that was cleaned up, rebuilt, Z28 valve springs. Stock polished crank Lunati cam- reverse duration efficiency design (212/202 adv dur, .465/.458 lift, 114 lsa) .030 over forged NOS TRW pistons
02-14-2012, 02:48 PM | #81 |
I just read through this and i am very impressed... I too talked to Tom Lowe and I recommend anyone thinking of going down the turbo path to talk with him... My question is how/where did you source your GN Turbo from. I would think that they are fairly scarce... Also, so you have any pics of your T5 and your exhaust install on your truck. Love to see how your shifter is placed in your cab and how the pipe(s) are run.... Very cool!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
03-12-2012, 05:03 PM | #82 |
subscribed
08-05-2012, 11:46 PM | #83 |
super cool build! do you have fuel mileage numbers yet?
08-06-2012, 08:37 PM | #84 |
Alright, I planned a route where I know the exact mileage. My OD is hooked up, but way off. I will post the MPG numbers when I get them. I am very curious to know.
Boucher' Posted via Mobile Device
08-07-2012, 12:58 AM | #85 |
never turbod a 6 but did plenty of 4 cyl in my yunger days...........................can you say FLASH BACKS
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
08-15-2012, 09:18 PM | #86 |
The numbers are in....
Did about a 50 mile cruise, two lane highway mixed with stop and go. MPG's = 17 all hand calculated with gps to measure distance. Not too bad for a 46 yr old truck! Boucher' Posted via Mobile Device
08-15-2012, 09:23 PM | #87 |
Very Nice! That is good to hear #'s like that out of a performance setup, it still keeps it affordable to drive!
08-15-2012, 09:24 PM | #88 |
Gearhead
That is awesome man!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
08-15-2012, 09:58 PM | #89 |
Awesome build! I may just have to stick with the 250 anyhow! Always thought a turbo would be cool. Sounds amazing, and thanks for posting all of the info with links. Amazing little truck!
Chris Posted via Mobile Device
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
08-15-2012, 10:09 PM | #90 |
pretty good mileage! do you run premium or are you able to get away with regular?
08-15-2012, 11:39 PM | #91 | |
I only run premium fuel. The engine is low compression, but I try to avoid detonation. I do not really drive it often, but when I do.. its balls out!
10-17-2012, 10:56 PM | #92 |
Love the truck! Any updates? I have a 250 as well and this thread inspired me to ditch the 8 and attempt to turbo the 6. Have you been able to go WOT yet and what kind of power do you think you're making? Also why the holley 350?
10-17-2012, 11:09 PM | #93 | |
I would like to put a blow-off valve on it. When I am in boost and I let off to shift all of that compressed air reverses and makes the turbo impeller flutter. If you listen close to the videos, you can hear it. I go WOT almost every time I drive it! To me, that is the beauty of a turbo. Your wastegate controls the psi, so WOT is no big deal. Power?.... I tell people, it feels twice as fast as compared to the stock 250. I would ROUGH estimate between 250-300HP. Holley 350? A turbo engine does not move more air, it just compresses it. So, the carb should be sized for the engine in NA form. All the best, Boucher http://youtu.be/JiAbg7MdpiU
10-18-2012, 02:14 AM | #94 |
Looks like I'm going with a holley 350 then, your advice plus researching other blow thru setups show it's a great choice for boosted 6's. Anything above 250hp would make me very happy. I'm ordering up a clifford manifold and possibly an SPA manifold to pair with it, thinking stock heads at low boost (6-8 psi). BOV's are good for the turbo but for some reason I love the sound of compressor surge. You need some WOT footage!!
10-18-2012, 10:07 AM | #95 |
compressor surge is hard on the turbo.
10-18-2012, 10:27 AM | #96 | |
you can get 250-300hp out of a 250 naturally aspirated 350-400+ range would be a better low boost goal. Stock heads on the 250 leave a lot to be desired... a few small changes that anyone can do in a home garage can really add some power. After my dealings with SPA and their manifold, I would never use one again! The still require a fair amount of machining to work properly, mine still had casting sand stuck in the corners and you Have to use an On center housing turbo to get it to fit with any of the intakes... and on-center exhaust housing turbos are not as efficient and harder to find the correct sized housings for! And your pretty much limited to a p-trim exhaust wheel then. Not trying to counter-dict or offend Boucher here but you may want to contact C & S carbs about the sizing.... n/a sized carbs DO NOT correlate to Blow through setups! Blow through is a whole different beast.... Also if this is going to be your first serious turbo build you may want to do some research over at theturboforums.com Good luck with your build!
10-19-2012, 02:49 PM | #97 |
iam doing research for a turbo on my 235 be basically the same set up .... its a stock rebuilt 235 where did you get you purchase turbo from ?does the j pipe off exhaust manifold get red hot ?
10-19-2012, 03:14 PM | #98 | |
As far as my carb, from a calculation standpoint. You can size your carb for your engine and then multiply it by 1.5. I should have probably used the same carb, just in the 500 cfm model. I found this one for $50 & couldn't pass it up. It does really good at idle and WOT. The only area of struggle is cruise /transitions. I made the mistake of drilling my PVCR's too big from the start. (.078"). My jets in there now are size 57's! The turbo is a factory takeoff, from a 1987 Grand National, including the wastegate elbow. Boucher' Posted via Mobile Device
10-19-2012, 08:12 PM | #99 |
VERY cool!! I like the fact that you got it figured out with help from others, not just dropped it off and paid someone to do it.
I gotta say, this seriously makes me re-think ditching my ole 235! Keep us posted!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
10-19-2012, 08:35 PM | #100 |
I contacted Tom Lowe, as well. Man that guy is a wealth of information and a nice guy to talk with to boot!.
My build is starting aith a late 70's 292 short block, decked .015" Using a head from a 1967 250 cid with one of Tom's cylinder head kits(1.84/1.6" valves,locks, springs, etc) Also installing a lump kit.(seemed like some easy HP for less than $100)Milled .020" Pistoms will be .040" over flat tops for a 307 cid with 2 valve reliefs, on 6" rods. Compression should be in the 9.3-9.5:1 range. Using a 1990 700R4 trans with a Alabama Converter Co.mild stall. Rear gears are 3.08:1. Hoping the OEM torque of the 292, with a little mid-range turbo help will make this a smooth combo for a 4000 lb Suburban Will be updating my build thread soon with pics from the machine shop and the recent body work. |
