10-19-2012, 09:15 PM | #1 |
3 speed column clean up.
Will I be ok, degreasing the section of the column that is not painted and paint it black again. will i need to grease anything when I'm done. Other then the area the rods for the shifting linkage .
10-20-2012, 08:49 AM | #2 |
Re: 3 speed column clean up.
Any takers ?
10-20-2012, 04:42 PM | #3 |
I am a Referee of life.
Are you talking about the underhood part?If so you can clean and degrease it well.Tape off the holes that various parts of the linkage enter the column and paint it.Then in each of those opening spray some white lithium grease.There is a write up(do a search) to adjust the shift linkage,that is a good idea before you dress up a pig. Good luck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
