Old 10-20-2012, 01:56 PM   #1
c10 custom
heat/ac fuse keeps blowing
hi guys i have a 1994 chev truck and it keeps blowing the heat/ac fuse you put the fuse in and press the button on the dash for power on the panel and it blows right away any help would be great thank you
c10 custom is offline   Reply With Quote
Old 10-20-2012, 04:23 PM   #2
RayInAlaska
Re: heat/ac fuse keeps blowing
The only thing that blows fuses are a shorts down the line. What I would do is to start at the end of the circuit and work my way back to the fuse as follows:
Disconnect the blower's motor, install a new fuse, and turn power ON. If the fuse blows, then you have to consider the switch itself, the resistor block, and any of the power leads all the way to the motor. If the fuse does no blow, then the motor is bad.
RayInAlaska is offline   Reply With Quote
Old 10-20-2012, 05:03 PM   #3
RayInAlaska
Opps! forgot the AC circuit. But for now try the heating circuit and see what happens.
