suburban 1/2 ton vs 3/4 ton weight
Obviously towing capacity is more, but how much more curb weight is a 3/4 ton late '70s 2wd sub vs an equal year 2wd 1/2 ton suburban? Both are 454 equipped.
Posted via Mobile Device |
Re: suburban 1/2 ton vs 3/4 ton weight
I had my 1990 3/4 ton 2WD burban on some scales and it weighed in at 7200lbs. and its a 454/th400 equipped truck.
My book says that a 1989 Suburban weights as follows:
1/2T 2WD - 4433 1/2T 4x4 - 4675 3/4T 2WD - 4816 3/4T 4x4 - 5128 A 454 would add a couple hundred more pounds.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
wow, i was thinking more in the 6k range.....that makes me feel like my z/28 is a brick at 3600lbs, haha.
i read somewhere the other day that 4wd k5's are in the 4k range too.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
Lol...yeah those factory manual numbers have to be off.....recently we took a load to the dump with a 3/4 4x4 Silverado K20 and empty with two passengers it weighed in at 6820lbs. So with my 90 Suburban weighing in at 7200lbs is probably correct too. And with 8-9 mpg I'd believe it! Lol
I know the pieces fit
I haven't weighed either of mine, but my 2wd is supposed to be around 4300 and my 4x4 around 5300. The 4x4 does have the heavier 6.2, a small block 4x4 truck should be closer to 5000.
I have weighed both my half tons, and if that is dry weight ( no fuel) they are right on the money.
