Old 09-25-2012, 08:29 PM   #1
laynrockers
laynrockers's Avatar
Question For those that have champion radiator. What did you do for Steam port?
Called champion today for a quote. 3 core with 14" or 16" fan relays and wiring kit, built in tranny cooler for $353.60 which is a great price compared to Entropy. This should drop right in with no mods and should suffice for the LS motor.
Question is what are you guys doing for the steam port. He told me they will not put one in and they do not come with them. ?
I have a LY5 5.3 from 07 tahoe. So mine is already plumbed and i just need to hook it up to radiator, unless there is another option.
laynrockers is offline   Reply With Quote
Old 09-25-2012, 09:24 PM   #2
OKGMC4
OKGMC4's Avatar
Re: For those that have champion radiator. What did you do for Steam port?
I spliced it into the hose with an aluminum adapter drilled for a hose barb. Others have had someone tig a barb onto the aluminum radiator itself. More than one way to skin a cat...
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 09-25-2012, 10:06 PM   #3
awhite4557
awhite4557's Avatar
Jaguars That Run (JTR) sells aluminum reducers /splices with the barbs, sight glasses, drains built in. Here's their websight http://www.jagsthatrun.com/Cooling-S...rts_Order.html
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 09-25-2012, 11:08 PM   #4
clinebarger
That says it all.....
clinebarger is offline   Reply With Quote
Old 09-26-2012, 11:07 AM   #5
laynrockers
Thanks guys.
Old 09-27-2012, 04:55 PM   #6
laynrockers
Update- They will add the steam barb for $50
Total comes out to $ 404.95
3 row rad. 16" fan, relay and wiring kit, built in tranny cooler.
This is for a stock LY5.
Old 09-27-2012, 09:58 PM   #7
TR65
TR65's Avatar
You don't have to weld in a steam port fitting, you can just use a bulkhead fitting with an o-ring. Drill a hole in the tank near the filler. You can access the nut for the fitting thru the filler hole. I have run this way for a couple of years, no problem.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-28-2012, 01:48 AM   #8
BigDan3131
BigDan3131's Avatar
Is there some reason you can't just plumb it into the expansion tank?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-28-2012, 09:02 AM   #9
TR65
TR65's Avatar
It needs to be on the high pressure side of the system.
TR
1965 C10 SWB Fleet
Two owner
Old 10-03-2012, 01:59 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
TR
Do you have a part number for this fitting? ... or at least a brand? Where did you find yours?
Rich
1972 K5 Blazer CST Click HERE
Old 10-14-2012, 08:04 PM   #11
BigShoe24
True Addiction
BigShoe24's Avatar
Guys,
Apologies for asking, but do all LS engines require this? Thanks
RCC
BigShoe24 is offline   Reply With Quote
Old 10-14-2012, 09:07 PM   #12
clinebarger
Originally Posted by BigShoe24 View Post
Guys,
Yes....There HAS to be a water cross over.
Old 10-14-2012, 10:14 PM   #13
TR65
TR65's Avatar
For MCMLXIX,
Sorry for the delay. I used a standard AN-3 bulkhead fitting. I sealed it against the tank with an o-ring washer as shown in the pics. Works good.
The champion core is leaking so I am switching to a Griffin made for our trucks with the LS swap. So the inlet and outlet are LS size and the steam fitting bung comes welded in.
TR
1965 C10 SWB Fleet
Two owner
Old 10-17-2012, 09:52 PM   #14
BigShoe24
True Addiction
BigShoe24's Avatar
Could someone post a picture of where the steam port attaches to the block? Thanks
RCC
Old 10-18-2012, 10:07 AM   #15
Wasted Income
Boosted Member
Wasted Income's Avatar
I drilled and tapped my water pump and ran it there.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-18-2012, 10:08 PM   #16
TR65
TR65's Avatar
BigShoe,
It is very difficult to get a picture of mine. Probably much better pic on the board somewhere but I hope this helps some.
TR
1965 C10 SWB Fleet
Two owner
Old 10-19-2012, 12:53 PM   #17
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
best shot I have of the steam tube...running from the front of one head to another (with a piece of rubber hose for vibration insulation in the middle) along the front of the valley pan... and then the barb you connect to, on one end of the tube pointing up, which has blue tape on it.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-21-2012, 12:48 PM   #18
BigShoe24
True Addiction
BigShoe24's Avatar
Ahh, ok. Thanks guys
RCC
Old 10-21-2012, 01:08 PM   #19
68GMCCustom
glad to help!
Kurt -
