Closed Thread
Old 10-19-2012, 05:55 PM   #1376
NEWFISHER
NEWFISHER's Avatar
Re: What Did You Do With Your Truck Today ?
Ordered more parts
NEWFISHER is offline
Old 10-19-2012, 10:47 PM   #1377
mknittle
mknittle's Avatar
I got most of the welding done on my frame boxing.
What a long week The neighbors had som construction going and the excavator pulled a 120 section of our water pipe out! It took 3 days to get fixed and now we don't have much water pressure
There must be a rock in the line.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 10-19-2012, 10:48 PM   #1378
yossarian19
Got the front clip most of the way off. Left a few bolts to soak in penetrating oil for a while longer. Broke 2 or 3 of them - oh well. First time it's been off in, well, maybe ever.
Once the clip is off, maybe Monday (truck lives at work) I'll start paint prep for the front frame section and start sizing up the motor mounts.
yossarian19 is offline
Old 10-21-2012, 10:59 AM   #1379
Chevette
Chevette's Avatar
Built a dolly for the cab last week. Today the cab comes off the frame, onto the dolly and I start finish welding the frame.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline
Old 10-21-2012, 01:39 PM   #1380
GMtrucknut!!
GMtrucknut!!'s Avatar
I removed all my hinges from the cab and put all new bushings in
GMtrucknut!! is offline
Old 10-21-2012, 01:52 PM   #1381
hotrod1
56 - autocross
hotrod1's Avatar
Where did u get the bushings?
hotrod1 is offline
Old 10-21-2012, 03:44 PM   #1382
arturo7
arturo7's Avatar
Opened up the box of the newly arrived AAW harness kit. Looked at the diagrams.
Holy snot, what have I gotten myself into?
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 10-21-2012, 05:39 PM   #1383
yossarian19
Showed the project to my co-owner & girlfriend, got a lot of blank looks for all my excitement.
Old 10-21-2012, 09:32 PM   #1384
Chevette
Chevette's Avatar
Woa! co-owner/girlfriend? That's worse that the mistake I made on my front suspension! You need to fix that problem.
56 Chevy PU
Chevette is offline
Old 10-21-2012, 10:18 PM   #1385
agnes the dog
agnes the dog's Avatar
Installed seat belts and took my 3 yr old for his first ride. You should have seen the look on his face. You would have thought he was in a parade. Took a couple hours to get the smile off his face!
agnes the dog is offline
Old 10-21-2012, 10:41 PM   #1386
NEWFISHER
NEWFISHER's Avatar
I had family in town all weekend. Took them to the airport and then started in on a couple projects. Pulled 3 leaf's from the front packs and 1 from the rear. Pulled the grille, headlamp bezels and painted them along with the grill trim and bumpers front /rear. Painted the wheels satin black and mounted the whitewalls. Changed all the fluids in tithe truck, oil bath and oil filter. I'm beat and headdred to bed early.
Old 10-22-2012, 12:54 PM   #1387
Daze57
Daze57's Avatar
arturo7
Sir. just take a package at a time and you will do fine - i was a bit taken aback when i got my harness also - but if you take your time - re- read your directions and follow the schematic you will be ok
hope this helps - good luck
Daze57 is offline
Old 10-22-2012, 01:11 PM   #1388
Wheelie
got my axles redrilled off my 8.8 for chevy pattern. Removed the load leafs from my spring packs in prep for the flip. Now recovering from the worst stomach flu I have ever gotten.
My '59 Build Thread
Wheelie is offline
Old 10-22-2012, 01:14 PM   #1389
Daze57
Daze57's Avatar
wheelie
yeah dem old trucks will do that to ya sometimes - gett better and back to it !
Daze57 is offline
Old 10-22-2012, 01:35 PM   #1390
OrrieG
OrrieG's Avatar
Finished the under dash ac mount except for minor stuff (kick diffusers and hose cover). Think I will move on to on to hanging the doors...
OrrieG is offline
Old 10-22-2012, 01:47 PM   #1391
OrrieG
OrrieG's Avatar
Originally Posted by Daze57 View Post
arturo7
break it down into pieces, lay it out on the floor first and reroute any lines from the major circuits (rear, front, engine, dash) that you need to. Look at where the box is going and how you are going to route each major ciruit, I made a big (24 x 36) schematic of the truck frame to help. Make notes. Get any accessories that did not come with the kit. Mount the box and start with the back (taillights, brakes, gas tank), then front (headlights, etc), then engine compartment and finsh with the dash. Do not shorten any wires until they are on the truck and ready to terminate.
Also, take a look at this guys page, good detailed information on how he did his truck. The link is to his build, also look at his link "electric shop", it has a good check list and general wiring info. http://www.alanhorvath.com/54chevy/ezwire_day1.php
OrrieG is offline
Old 10-22-2012, 01:50 PM   #1392
OrrieG
OrrieG's Avatar
I would be nervous and figuring out a way to get the co-ownership corrected if her level of excitment is low or lacking. She might decide she needs a new pair of shoes and sell her interest to a third party....
OrrieG is offline
Old 10-22-2012, 07:35 PM   #1393
arturo7
arturo7's Avatar
Thanks for the advice and encouragement on the wiring, guys.
I took a long look at the garage today and decided it could use some attention. Need to add more lighting, more outlets, more shelving, and give it a good de-clutterization before the chassis arrives. Guess I'll meander over to the garage threads for inspiration,
ever forward
arturo7 is offline
Old 10-22-2012, 07:48 PM   #1394
yossarian19
Got the I-6 exhaust out, removed the last of the old fuel line, set the front body work on a pallet for later, got 1/3 of the rivets for my shock mounts off / out (prep for power steering kit), got the I6 mounts out of the cross member. Some more de-griming with a putty knife & a dental pick.
Almost ready to pull the steering box & buy some engine mounts, see how this is going to line up.
Old 10-22-2012, 08:19 PM   #1395
retired1
started preparing my 55 2nd project for storage for the winter while I go to Arizona where I have a 69 shortbed stepside to tinker with.
retired1 is offline
Old 10-23-2012, 12:31 AM   #1396
yossarian19
Oh, and I bought the engine & trans cross members I'll need from CPP.
Next: pressure washing, priming & painting the frame + maybe do the power steering project.
Old 10-23-2012, 12:44 AM   #1397
NEWFISHER
NEWFISHER's Avatar
Painted the steelies body color
Old 10-23-2012, 02:14 AM   #1398
agnes the dog
Removed the ridiculous trailer hitch that the PO had installed.
Old 10-23-2012, 03:39 AM   #1399
Iceman_70
Iceman_70's Avatar
Did some welding practice on my firewall ... Still a long way to go before I can put in new cab corners
Iceman_70 is offline
Old 10-23-2012, 04:11 PM   #1400
_Ogre
_Ogre's Avatar
looks good iceman
cleans up the firewall
shop air compressor timer
_Ogre is offline
Closed Thread
