Old 10-16-2012, 05:09 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
New Relocated Tank -
Had to share these pics. This is one of the several projects I've been working on during the blazing hot summer months.
I'm slowly getting my stepper ready for a cross-country haul and wanted a bigger relocated tank. Just didn't want a blazer tank for a variety of reason. This is a Tractor Supply toolbox with extended struts to allow full opening. The cell is a 19 gallon RCI Fuel cell, modified by extension to 28 gals. Mounted on shock mounts inside the toolbox.
All steel lines for rollover vent and supply. Hope you like it.
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 10-16-2012, 05:17 PM   #2
68 TLC-10
Re: New Relocated Tank -
That's so cool. You wouldn't expect a fuel tank to be inside the tool box. How much did it cost you to fab up if I may ask?
68 TLC-10 is offline   Reply With Quote
Old 10-16-2012, 05:42 PM   #3
68Stepbed
68Stepbed's Avatar
Pretty sweet, man!! I'm looking forward to hearing about the comments you'll be getting at gas stations.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-16-2012, 07:18 PM   #4
TobyArnot
TobyArnot's Avatar
I found the almost new toolbox on CL for $150. The fuel cell was $200. The tank extension was another $150. Another $170 for the four mounting straps, steel plumbing, and shock mounts, hardware, etc.
So I guess the whole deal was about $520 plus the toolbox. I had designed several versions of the tank itself and had quotes from $500 - $700, so by using the RCI Cell, I got all the fitting, filler and 90 ohm sending unit. Saved a few bucks that way.
I'm going to finish hooking up the plumbing and pull the old tank A.S.A.P.
Here is a .pdf file rendering from SolidWorks
Old 10-16-2012, 07:49 PM   #5
CParnell
CParnell's Avatar
That`s pretty cool.
1968 GMC 910 Project Tommy
1974 Olds Cutlass
CParnell is offline   Reply With Quote
Old 10-16-2012, 09:13 PM   #6
pat 70/71
pat 70/71's Avatar
thats slick and because its higher than a under bed tank you wont have any fuel flow back issues. good job! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-16-2012, 10:42 PM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Re: New Relocated Tank -
That is sweet right there man! I like!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-17-2012, 07:25 AM   #8
TobyArnot
TobyArnot's Avatar
Thanks for all to good comments gang. I wanted to get the Fuel Cell out of the weather. I'm even thinking about adding a second toolbox to use as a "trunk" for hauling travel bags and folding chairs..
On a side note, once I pull the stock tank, should more cab noise be a problem I should address? I have some nice 6 x 9's under the seat and I will move them back. The PO installed a carpeted tank cover, which I could reuse.
Again thanks and looking forward to JRMotorsports this Sat. in Mooresville, N.C.
Old 10-17-2012, 10:42 AM   #9
68 TLC-10
Hey Toby, that drawing is from Solidworks? I use Solidworks at work. I also use Pro/e or Wildfire as PTC calls it now. I'm a mechanical designer by trade.
Old 10-17-2012, 11:06 AM   #10
Tinkermc
nice outcome to a problem we all share
Tinkermc is offline   Reply With Quote
Old 10-17-2012, 01:22 PM   #11
TobyArnot
TobyArnot's Avatar
Solidworks 2012. I've been doing mechanical design for over 30 years. Used 2D AutoCad for almost 20 years. Wouldn't want to go back to 2D ever again.
Old 10-17-2012, 02:44 PM   #12
JointTech
JointTech's Avatar
ive been beating my head on the wall with inventor fusion and autocad. You guys make it look easy.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 10-17-2012, 02:53 PM   #13
TobyArnot
TobyArnot's Avatar
Keep the faith - Experience is a great teacher. P.S. I lived in Mission Viejo for several years. Worked in RSM.
Old 10-17-2012, 04:28 PM   #14
yuccales
yuccales's Avatar
Very nice!
yuccales is offline   Reply With Quote
Old 10-17-2012, 07:50 PM   #15
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Relocated Tank -
I hope you have the truck with u? I want to checkout the tank.
When u take the tank out of the cab you will have plenty of room for more speakers. Remind me I'll show u mine. Another thing u will have the gas opening to plug. I used a old plastic cap for years until I had it welded up this last repaint. Worked great.
http://67-72chevytrucks.com/vboard/s...t=gas+cap+plug
Old 10-18-2012, 07:09 AM   #16
TobyArnot
TobyArnot's Avatar
Thumbs up Re: New Relocated Tank -
Sounds great Andy,
Yes, My stepper is my only ride. D/D and cruiser. I'll be driving it for sure. Ask me about some of my "road trips". I use it a lot. (Daytona Turkey Run for Thanksgiving) That's one reason I'm confident enough to plan a Cali. trip with a single axle camper. Call me foolish, but I'm mostly just old and dumb!!!
JointTech, I'm headed your way_ _ _ _
MY MOTTO:
Old 10-21-2012, 09:58 PM   #17
MYKG C10
i like the idea wonder if you use a used an old army ammo boxs that large cal rounds
MYKG C10 is offline   Reply With Quote
