meowMEOWmeowMEOW
Re: 67 bagged and want a 5.3, but need help!
adapter plates for the motor mounts, drill new holes and move trans mount to new spot (depending on where engine sits), wiring harness, pcm, tac and pedal IF its dbw, driveshaft cut to length, any misc sensors that were damaged or not working, fuel pump (possibly new tank depending on choice of pump and current tank style).
Thats a start, but there are things like gauges, shifter etc that may need work depending on what parts you choose.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Well I found a setup I think. I hope I can do this swap.
Posted via Mobile Device |
Backed out, it was a 2002 with 197,000 miles.
