Old 10-20-2012, 09:02 PM   #1
slugish
Slugish
Lifter tick help
AFTER MR TRUCK WARMS UP , IT SOUNDS LIKE iMIGHT HAVE A LIFTER TICK . hAVE NEW COMP CAM , COMP HYDRAULIC LIFTERS & NEW ALUM HEADS.( RHS)
hOW CAN iTELL IF IT IS IN FACT THE LIFTER MAKING THE NOISE .
HOW DO iTELL WHICH ONE IT IS
wAS VERY CAREFUL IN SETTING VALVE LASH & ADJUSTING . LASH AT ZERO- THEN TIGHTENED LITTLE PAST 1/2 TURN --SOAKED LIFTERS IN OIL BEFOREHAND.
dO I JUST NEED TO TAKE VALVE COVERS OFF & ADJUST OLD SCHOOL WHILE ENGINE IS RUNNING --IE TIGHTEN TILL TICKING STOPS.
ALL HELP APPRECIATED , wILL
slugish is offline   Reply With Quote
Old 10-21-2012, 01:16 PM   #2
notyo_cheez
Cool Re: Lifter tick help
Use a mechanic's stethescope or a long shaft screwdriver with the handle against your ear (really old school) if you don't have one.
notyo_cheez is offline   Reply With Quote
Old 10-21-2012, 01:51 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
The old school adjusting always works for me. Take out slack till it slaps then toghten till it don't then go 1/2 turn. If another rocker is ticking where your working but you can't tell push down on them one by one till you find the loose one wich will quiet up when pressed.
Be sure that all exhaust gaskets are sealed good and the intake has no leak at the heat riser runners or egr if you still have it.
Also comp cams are known to be kinda noisy since the ramp profiles are very fast. This will sound like quiet knocks or lugging. Claclaclaclaclaclaclaclaclacla.....
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-21-2012, 04:51 PM   #4
slugish
Slugish
Thx Insidious ,
Yea ,Ireally need to check & make sure header bolts are tight.
That interesting about comp cams > dont understand how the ramp profiles would make noise . Of course there are a lot of things Idont understand .
I just put on copper gaskets on my cheap hedman long tubes when Iput engine back together . You mentioned graphite > maybe copper being pretty rigid dont seal so good .
The sound Ihear does sound like a quiet knock come to think of it ?
Old 10-21-2012, 06:38 PM   #5
71maligreen
also check header gaskets for leaks, if you have headers or loose header bolts they can sound exactly like a lifter ticking!!!
71maligreen is offline   Reply With Quote
Old 10-21-2012, 07:43 PM   #6
INSIDIOUS '86
REMFLEX gaskets yes they are graphite half inch thick and real good
Old 10-21-2012, 09:28 PM   #7
71maligreen
I use felpro steel core gaskets and they never leak!!!!
http://www.jegs.com/i/Fel-Pro/375/14...rentProductId=
Old 10-22-2012, 02:59 PM   #8
oldmann1967
FYI, Caps mean you are YELLING.
oldmann1967 is offline   Reply With Quote
Old 10-22-2012, 04:26 PM   #9
INSIDIOUS '86
LOUD NOISES!!!
