Old 10-22-2012, 12:49 AM   #1
heathbirkendahl
Sway Bar
What front sway bar are you running? I'm looking at the one from Early Classics. Any feedback?
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 10-22-2012, 01:40 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Sway Bar
Anything from Early Classics is top notch. With that being said you can save some money by going to a wrecking yard and pulling a front sway bar off any 1973-1987 Chevy or GMC pickup or 1973 to 1991 Suburban usually for around 25/50 bucks. You can use one from a 1500/2500/3500 as the heavier trucks had thicker bars with the max thickness I believe was 1 and 1/4 inches. I have a 1 and 1/4 inch sway bar on my truck, from a 70's 9000lb. Camper Special Chevy, with Early Classics brackets for lowered trucks and installing a front sway bar is super bang for the buck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-22-2012, 02:45 PM   #3
mtnbikeman
Re: Sway Bar
Junk Yard bar for me. Pulled if off a 76 3/4 ton camper special. 1 1/4'' for $25. Also used ECE lowered brackets and new bushings and straps. Im into it for may be $80.
mtnbikeman is offline   Reply With Quote
Old 10-22-2012, 10:22 PM   #4
heathbirkendahl
Re: Sway Bar
Thanks guys. All great options.
