Old 10-22-2012, 11:58 PM   #1
noob
door hinges 55-59 truck
I'm in the process of installing my door hinges and recently learned I put the upper on the lower part of the door and vice versa. My question is, does the rear of the hinge bolt to the cab? There are two bolts up front, but there is a single bolt hole to the rear of the hinge where it rests towards the firewall. Does anyone have pictures of the correct way to mount these hinges? My wife and I bought this shell of a truck with 5 plastic containers of parts that we are trying to make sense of. Any help is appreciated,
noob is offline   Reply With Quote
Old 10-23-2012, 11:41 AM   #2
OrrieG
OrrieG's Avatar
Re: door hinges 55-59 truck
Ignore the upper right hand corner, it is for 5000 series. It is a lot easier if you make a jig for your floor jack to support the weight of the door. Here is one, you can also use an engine hoist and sling.
http://stovebolt.com/techtips/doors/cradle/index.html
Old 10-23-2012, 12:59 PM   #3
noob
awesome. thank you. turns out i put them on the wrong side
