10-24-2012, 10:57 AM | #1 |
Bell Housing Mount Help
My bellhousing motor mounts on my 66C10, with original 283 are quite swollen, and cracked, are these the correct replacements, and should I stick with rubber, or go with Urethane?
Also, have not pulled the engine yet, and the front mounts look good, should I consider replacing these as well? If so, do I need to replace the entire mount, or is there a "rubber" that can be replaced? Thank you in advance for your input.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
10-24-2012, 10:58 AM | #2 |
Re: Bell Housing Mount Help
Those look like the correct ones for a manual transmission.
10-24-2012, 11:04 AM | #3 |
Urethane has a higher load bearing capacity, greater tear strength, better compression set, greater abrasion resistance, is more tolerant to greases and oils. I feel its worth the extra money personally. Rubber is biodegradable and is affected by ozone...they will dry rot and degrade over time. Urethane will keep going and going.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-24-2012, 11:24 AM | #4 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
10-24-2012, 12:19 PM | #5 | ||
10-24-2012, 07:51 PM | #6 |
i just got the 79-161 poly ones.they fit great,made by prothane,the metal parts are zink coated as well,i also went with the prothane front engine mounts,good quality.seems to me the only rubber mounts from anyone is offshore junk.i went with poly cab mounts also.cheers
