Closed Thread
Old 10-24-2012, 11:14 PM   #5201
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: What did you do to your truck today!
Pics?
Okay, ole dollor.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-25-2012, 12:35 AM   #5202
jc70chevy
jc70chevy's Avatar
just lmao at mags reply
jc70chevy is offline
Old 10-25-2012, 12:37 AM   #5203
ole dollor
ole dollor's Avatar
Pics?
Okay, ole dollor.
thanks, thats a lot better. now i know how you did it......
ole dollor is offline
Old 10-25-2012, 01:09 AM   #5204
jd7
jd7's Avatar
Started my baby today !!!!!!!!! Fresh built 350 motor with lots of machine work and lots of goodies,camel back heads ported and polished,holley carb,edelbrock intake, TH400 trans bullet proof I hope stall converter, lokar kickdown kit, headers,magnaflow mufflers,black magic extreme fan. Going to break in the cam 2mro and readjust the valve lash.Can't wait to drive it.
jd7 is offline
Old 10-25-2012, 03:22 AM   #5205
silverbullett
Replaced blown header and collector gaskets with new ones from Remflex and added ARP hardware to the mix. Now I just need to get rid of these old rusty mufflers.
silverbullett is offline
Old 10-25-2012, 09:53 AM   #5206
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Phooey ~
Thanx for trying anyway .
Back to the Jaguar SMITH'S gauge I guess .
Looking at the corroded PC there , I imagine it's just a matter of taking some serious time to disassemble the entire dash binnacle and ever so carefully hand polish each and every connection , especially where the MPC plugs in ~ those female contacts are usually brown and they need to be shiny copper colored to have accurate gauges ~ I've done several of these now and the improvement in fuel gauge accuracy and ilumination is amazing .
However , it's very easy to ruin the PC if you're rough on it when polishng .
Also , you'll need to schlepp on down to SEARS or where ever and buy some thin ignition wrenches so you can hold the inner nuts from turning as you loosen the outer nuts on the PC , as soon as they twist , the delicate PC's mylar is ruined...
Adding a ground wire from the binnacle to the cab's frame is always wise as is replacing the usually gone missing braided ground straps from engine to cab , engine to frame , cab to frame , core support to frame and so on ~ try this , your headlights will *instantly* be white at night and your battery will charge up faster too....
All these gaugse work on milliamps so anything that hinders current flow , makes them balky and inaccurate .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-25-2012, 05:34 PM   #5207
flushdrew
it's 38 degrees here today, and i'm heading out to go replace the hub with the new assembly i got.
$25 at a place in the next town over.
wheel hub, dust cap, taper bearing, bearing seal, brake drum and lug studs.
we'll see how it goes.
flushdrew is offline
Old 10-25-2012, 07:02 PM   #5208
Mr.Hyde
pricing parts and planning financially how to attack this build. The biggest question is drive train and how to get the box and cab home haha...
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline
Old 10-26-2012, 02:28 AM   #5209
Pont406
made some passes...
Pont406 is offline
Old 10-26-2012, 03:03 AM   #5210
hpcgmc
hpcgmc's Avatar
VWnate - what's a "pc" that you are referring to?
Flushdrew - sounds like a lot of progress in a week - I've got to get to work on sanding and priming my beast soon!
Pont406 - love the pic of the old beast at the track! What times did you turn?
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline
Old 10-26-2012, 08:11 AM   #5211
ryanroo
ryanroo's Avatar
PC = printed circuit. the funny plastic thing on the back of the gauges that has the copper tracks running through it
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 10-26-2012, 09:09 AM   #5212
VWNate1
VWNate1's Avatar
It's Friday and the plan is to yank the pre - smog cylinder head off my '66 292 and get it to the Machine Shop for a total rebuild , I plan to put it on my ailing 250 then set about overhauling the 292 , not sure what I'll do with it when it's done .
-Nate
Geezer
VWNate1 is offline
Old 10-26-2012, 09:30 AM   #5213
flushdrew
hpcgmc thanks! - the truck i bought was pretty close to road ready, but the PO had done some work on the body but never sealed it. so it was rusting. rust protection was priority 1.
Old 10-26-2012, 09:34 AM   #5214
Shyguy
Junior Member
Shyguy's Avatar
We continued getting the '67 cab and front clip ready for putting on the primer. I did paint and surface rust removal with a random orbital sander while my son patched a few spots and layed on a thin layer of bondo here and there.
Sanding is slow going when it gets to where hand sanding has to be done for the feathering in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 10-26-2012, 12:15 PM   #5215
bigdog57
bigdog57's Avatar
just got my baby out of mechanic pergatory. (he had it for two months) it only cost an arm and a leg to get new heads put on it.
Bigdog
bigdog57 is offline
Old 10-27-2012, 12:49 AM   #5216
ItsRandy
ItsRandy's Avatar
Went to the upholstery shop to pick up my truck, it wasn't done yet. The seat was back in it and the door panels were done but not installed. I was told I will be able to pick it up tomorrow. The upholstery guy still has the headliner, dash pad and sun visors left to finish.
ItsRandy is offline
Old 10-27-2012, 01:42 AM   #5217
mud.man.rj
mud.man.rj's Avatar
Good work takes time and the work looks good.
mud.man.rj is offline
Old 10-27-2012, 10:39 AM   #5218
VWNate1
VWNate1's Avatar
Pulled the head off the 292 , it looks a bit grim in there .
Dropped the head off for rebuilding and made arrangements to buy a four wheel engine stand to - day after my Union meeting , maybe I'll be able to get the engine hoist and get the 292 off the ground and onto the stand so I can begin disassembling it .
-Nate
Geezer
VWNate1 is offline
Old 10-27-2012, 11:18 AM   #5219
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
That seat looks comfy...like the door panels too. May I make a suggestion before you add those door handles...I am looking at these for my truck. 55-66 armrests...they have a better look and fit the same hole spread (I understand) on the doors.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 10-27-2012, 11:31 AM   #5220
70CHEVYBB
70CHEVYBB's Avatar
My new doors and bumpers showed up wednesday. Its to bad I managed to order a gmc bumper instead of a chevy front bumper. I installed the rad support and fenders and doors. I can now align it all up and weld in the rockers and cab corners. I have a commercial sand blaster with 185 cfm diesel compressor being delivered next week to my house to use for free. I have alot of work to do to get ready for that.
70CHEVYBB is offline
Old 10-27-2012, 02:30 PM   #5221
ItsRandy
ItsRandy's Avatar
Thanks for the suggestion.
ItsRandy is offline
Old 10-27-2012, 02:48 PM   #5222
68GMCCustom
n/p...you may prefer the stock ones...just thought I'd throw it out there.
Kurt -
Old 10-27-2012, 03:04 PM   #5223
pat 70/71
pat 70/71's Avatar
Gave her a bath and a heavy boot on the gas pusher thingie! cheers, Pat
pat 70/71 is offline
Old 10-27-2012, 08:04 PM   #5224
Shyguy
Junior Member
Shyguy's Avatar
My son and I finished the body work and sanding on the cab and front clip today. I am learning a lot on this build from my son.
Tomorrow we will clean up the truck and get it ready for wet sanding.
Shyguy is offline
Old 10-27-2012, 10:03 PM   #5225
ItsRandy
ItsRandy's Avatar
No it's not deja vu or a the beggining to a bad joke...I went to the upholstery shop to pick up my truck today, it wasn't done. The door panels were installed and my upholstery guy was working on the headliner. Should I hope to pick my truck up tomorrow?
ItsRandy is offline
Closed Thread
