10-23-2012, 10:53 PM | #1 |
bagging a 1966 chevy truck
im getting ready to bag along bed fleetside 66 chevy truck. How do i determine what size bags to use?
10-24-2012, 04:21 PM | #2 |
Re: bagging a 1966 chevy truck
Weight of truck. A lot of people say 2600. I have 2500s
Posted via Mobile Device |
10-24-2012, 08:08 PM | #3 |
Who Me?
I have used two chamber bags in the front of my old 65, but I hear single chamber in the front is better to keep down body roll. The single chamber bags will be shorter and less range of movement.
At some point I plan to bag the front of mine and will go with single chamber bags. AS far as weight rating, is 100# really going to make a difference? I would say 2500 and 2600 would work fine. If you are running a V8, I would go with 2600# just for the little extra load cap.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-25-2012, 09:56 AM | #4 |
2600 in the front , wither 25 or 26 in the rear
always put the the biggest bag u can in because u get more lift with less psi and in return its a more comfy ride also works in in reverse too smaller bag = more psi firmer ride i have 2600 in all four Posted via Mobile Device
///Relaxed Atmosphere |
10-25-2012, 11:17 AM | #5 |
I have 2500's all around. I cupped my LCA's so I didnt want to have any rubbing issues with the bigger bag. Now that its all said and done, i PROBABLY could of used the 2600's up front, but the ride is still pretty sweet. Something to consider if thats the route your going
10-25-2012, 12:20 PM | #6 |
I have ordered a porterbuilt kit from Pro Performance is AZ, it is a simple kit so that I can adjust my ride height if I have a load, or am towing my camper (no C-notch). There is a picture of the kit in my build thread.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
10-25-2012, 08:19 PM | #7 |
Most bags kits will run the double convoluted bag, which does have more travel. A lot of the kits we sell will use the slam specialties SS7 bag, which is a good all around bad. They also have built-in internal bump stops which is a nice feature.
Craig, Just checked out your build thread.... It is looking good. Posted via Mobile Device |
