10-25-2012, 02:39 PM | #1 |
Mustang II IFS
I’m considering to install a Mustang II IFS on my 56 chevy truck… I thought I saw somewhere on the net that the MII with standard spindles will lower the front with 4” … is this correct ?
Any suggestions to lower the back 4” as well ? I saw some people flip the rear, but if my estimates are correct this lowers the rear 7”-8” |
10-25-2012, 04:21 PM | #2 |
Re: Mustang II IFS
flipping the rear on top of stock springs will lower the back 7''
i have a fatman mustII and it looks like this
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-25-2012, 04:47 PM | #3 |
Re: Mustang II IFS
Looks great, Ogre!
10-26-2012, 05:53 AM | #4 |
Re: Mustang II IFS
10-26-2012, 09:03 AM | #5 |
Re: Mustang II IFS
Ogre, Your truck DOES look just right. May I ask how wide your rims are and if you have any rubbing issues on turns? Did you C notch the rear?
Posted via Mobile Device |
10-26-2012, 05:43 PM | #6 |
Re: Mustang II IFS
i should have added... fatman mustII with standard front spindles
i can't imagine having 2'' more of drop, it wouldn't be streetable. at dip: (you chose that name not me ) with the fatman and 3rd gen rearend i use 7x15 up front and 8x15 in back, both with 4'' back spacing all with P235/70R15 black walls, though i will go with skinnier tire up front next time. fronts rub a bit locked to the right, barely backs have 3'' mini tubs in the bed and i can barely get my pinky between the fender and the tire. and yes to the c-notch. 3'' c-notch. but go with 4 or 5 instead, i had to put air shocks on mine.
