10-23-2012, 09:35 AM | #1 |
rocker box question
I have a 1972 k5 and was wondering if it originally had rocker box rear reinforcement plates or is that a new improvement for our vehicles? I just bought new rocker boxes and end caps for it but didnt want to pony up for the reinforcement plates yet. Thanks
Posted via Mobile Device |
10-23-2012, 11:40 AM | #2 |
Just a nother gear head
Re: rocker box question
Yes the plates are stock and if yours are rotted out you need to buy them.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
10-23-2012, 02:00 PM | #3 |
Ok, to make sure then there are three total pieces per side.
10-23-2012, 02:52 PM | #4 |
Ive been looking at the lmc book myself trying to figure it out. Ive helped replace rockers, thats it.
Someone correct me if I'm wrong. From outside in, you have... rocker some flat plate? some z bent plate flange thats part of the floor rocker box? |
10-23-2012, 04:52 PM | #5 |
Here's a picture of the bottom of my rocker box plate. I have more pictures if it helps. Hopefully this helps.
10-23-2012, 05:32 PM | #6 |
Oh, ok, i thought you guys were talking about the rocker box, when in fact its the torsion box.
Or am i wrong? The floor has a ninety degree bend on the outside, under the door,and the rocker gets spot welded toit. Then the torsion box gets spot welded to the lower flange of the rocker box, floor flange
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-23-2012 at 05:37 PM. |
10-23-2012, 05:57 PM | #7 |
I might be wrong. Sorry if I've confused the question.
10-23-2012, 06:09 PM | #8 |
99 ls1 ss, thats what I'm talking about but do you have a picture from the other end? Im trying to figure out the re inforcement plate location.
10-23-2012, 06:11 PM | #9 |
OR.... is everything pictured at this end. Its hard to tell when youve never seen the actual install of something. Thanks
10-23-2012, 09:58 PM | #10 | |
10-23-2012, 11:16 PM | #11 |
Member #1049
If I understand you correctly. You are asking about these, and yes Blazers came with them from the factory and by now they usually are rusted out..
The second picture is of one installed on a Blazer that has the lower quarter cut off |
10-24-2012, 06:24 AM | #12 |
Thanks everybody, you guys have answered my questions and the pictures are very helpful. Guess I better buy those two but they sure are expensive, I'm assuming because of all the bends/ labor to make them.
10-24-2012, 10:26 AM | #13 |
Member #1049
Yes they are expensive compared to all the other pieces, your assumption is correct, they have a number of difficult bends and are made by hand, one at a time.
10-24-2012, 10:50 AM | #14 |
cant say Ive seen that part. Time to look
10-24-2012, 01:15 PM | #15 |
Dale, I dont believe lmc carries those. most guys get them from gmc pauls or brothers. they are a little on the pricey side at around 140 a piece i think.
10-24-2012, 04:03 PM | #16 |
I'm saying I dont even think I have seen them on my jimmy, and I know I have looked in that area, cause it was packed full of mud.
10-26-2012, 09:14 AM | #17 |
:delete:
10-26-2012, 10:12 PM | #18 |
completely rusted away. as are mine.
