10-26-2012, 10:27 AM | #1 |
Bleeder valves
I need to bleed the disc brakes on my '72. Bleeder valves are stuck...any ideas on how to break them loose. 6 pt socket started rounding them off. Should I just get them off and replace the valves? Anyway to save them? Replaced front brakes and have no front brakes now...frustrating.
10-26-2012, 10:54 AM | #2 |
Re: Bleeder valves
heat them up with a torch I also have good luck hitting them with a hammer to shock them than wrenching them out but you will need to replace the bleaders hope this helps you out
Fuzzy |
10-26-2012, 10:57 AM | #3 |
Re: Bleeder valves
Soak with some good penetrating solvent over night, then heat the caliper around the valve with a hand torch. Spray again while hot being careful not to start a fire or breathe the fumes. A cycle or three of that should help immensely. Like Fuzzy said above rap it with a hammer. Also try to work the bleeder back and forth - tighten & loosen etc ...
If that doesn't do it your local shop may have repair kits. You (or they) basically drill out the stuck valve, re-tap new threads, then install a new over size insert which has a new needle seat built in.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
10-26-2012, 11:24 AM | #4 |
Re: Bleeder valves
calipers are pretty darn cheap and sometimes it is better to just get a new pair so you have all new brakes to start off with
10-26-2012, 02:18 PM | #5 |
I am a Referee of life.
Re: Bleeder valves
I think cdowns hit your answer.If the bleeders are that bad then the calipers probably could stand to be replaced.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-26-2012, 04:16 PM | #6 |
Re: Bleeder valves
Thanks I'll try the suggestion and buy new if needed. I thought about heating, but wasn't sure if it would ruin any o rings I hadn't thought of.
10-26-2012, 04:29 PM | #7 |
Re: Bleeder valves
There is always that chance. I have removed countless stuck bleeders that way. One has to be smart and not cook the whole caliper.
10-26-2012, 10:05 PM | #8 |
Re: Bleeder valves
I used a brazing tip on my torch to concentrate the heat. I see Vautozone has rebuilt calipers for $12+ $10 core charge.
10-26-2012, 10:25 PM | #9 |
Re: Bleeder valves
VISEGRIPS WILL DO IT MAN always!!!
