Old 09-25-2012, 12:19 AM   #1
slammed6t4
67 painless LS1 wiring woes
not sure if anyone else out there has done the LS1 swap using painless harness for the truck and incorperated the Painless LS1/4L60 harness.
got a few questions regarding merging the wiring for Brake switch, the Neutral/Safety/reverse switch and Alternator wiring.
I got a 4 wire brake switch, think i've figured out this dilema but if anyone can reassure me about it that would be great.
The Neutral safety switch/reverse switch is the one bothering me the most and the Alternator wiring. I have a 4 wire neutral safety/reverse switch and I'm using a corvette LS2 2 wire connector style alternator.
anyone that can lend me some insight that will help is greatly appreciated. wiring is the last on my list of this swap and i wanna get it done.
Thx in advance.
slammed6t4 is offline   Reply With Quote
Old 09-27-2012, 10:30 PM   #2
clinebarger
Re: 67 painless LS1 wiring woes
More info needed...
Year model of truck.
Year/make/model of engine.
Painless engine harness number.
Original body harness? Painless, Other?
So your alternator is off a LS2? LS2 GTO/G8's have a Denso alternator.....Corvette/Trailblazer use Delphi.
PCM number?
clinebarger is offline   Reply With Quote
Old 09-28-2012, 12:44 AM   #3
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Read my 87 build thread around the last 1/4 or so.
There are some pocs of how I did my brake switch in there and how I wired it.
Thx in advance.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 10-25-2012, 11:27 PM   #4
slammed6t4
TTT
Originally Posted by clinebarger View Post
More info needed...
Year model of truck. 67
Year/make/model of engine. 98 corvette LS1
Painless engine harness number. #60506
Original body harness? Painless, Other? Painless harness #10206
alternator that is currently in the truck is a LS1 GTO alternator from a 2005,
i wired the alternator as follows, battery to starter: starter to lug on alternator. 2 wire connector, 1 wire jumped to alternator lug and other wire tied into 12v activation wire from painless truck harness. the way i have it wired the truck works perfect, charges at 14.2v while idling. everything seems fine and dandy, til the other day battery DEAD truck wont start.
Question is did i wire this wrong and its causing battery drain or do i have something else going on. Do i have to wire the resistor into the wire like i've been reading about or no?
PLEASE HELP!!
Thank you in advance
Old 10-29-2012, 09:42 PM   #5
slammed6t4
TTT anyone out there lend a hand on this one.
